Results 1 to 4 of 4
Thread: Paranoia - FTW
    Senior Member Three Rings ad03avant's Avatar
    Jun 21 2008
    2003 A4 Avant Quattro
    Olympia, WA
    Paranoia - FTW
    I just noticed for the second time when I pulled into the garage and shut off a burning oil smell after shutting the garage door. Never notice it any other time, e.g., in parking garage at work or out in the open.
    I have already had a valve cover gasket replaced and timing/belt job done about 5,000 miles ago. Running with 59,000 miles. What the hell is that smell. It goes into the Audi dealer tomorrow for the timing belt check, I can have them check it out, but dont want the stealership trying to get me to spend more money than I need. Im already letting them change the oil so I can get the free timing belt inspection....
    What the hell could be going on with this low milage and a new valve cover gasket? Any typical leaks I should watch for? Im chipped APR 1 but engine wise thats about it...
    D
    Andy
    -2003 A4 Avant Quattro
    -APR Stage 2 +, Achtuning Snub, Avic D3, USP Front, S4 blades and bi-xenons, APR stealth, 034 HFC, ASA JH3 18', platinum VMR sport gauge, h-sport sways, ABT springs, Koni sports, Zimmerman sport rotors, Stoptech stage 1
    Jun 21 2008
    Olympia, WA
    Re: Paranoia - FTW
    biggitybumpforthatass
    Andy
    Registered Member Two Rings bigbro's Avatar
    Jul 27 2008
    Black 05 b6 a4 1.8T Quattro AT
    Re: Paranoia - FTW
    My rear coolant flange had a smell similar to burning oil, although it was coolant burning after I got it fixed the smell went away. Hope this helps
    05 Triple Black 1.8T Quattro Tip.
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Re: Paranoia - FTW
    cam tensioner seal
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
