Results 1 to 12 of 12
Thread: headlight mods
    Jul 19 2008
    united states
    headlight mods
    are there any headlight mods i can do to cure the condensation problem on my 05 a4? i know about changing the o-rings but am not sure if that is the direction i want to go.
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    Re: headlight mods
    i heard you can tape a silica gel pack in the cover to absorb the moister but i cant confirm
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings JerseyShoreA4's Avatar
    Jun 17 2007
    2006 VW Touareg (on blocks in my driveway). 2007 a4 2.0. 2003 a4 1.8tqm sport (sold)
    Ummm the Jersey Shore
    Re: headlight mods
    silica packet helps. go raid your shoe boxes. You can also try to rtv seal the black portion of the housing to the clear part of the lense.
    Miss my B6
    Senior Member Two Rings JonnyQ's Avatar
    2003 A4 3.0 quattro 6spd
    Long Island, NY
    Re: headlight mods
    Quote Originally Posted by yeldarb View Post
    why wouldn't you try the o-rings? Its cheap and easy to do. and completely reversible if for some reason you wanted to take them out.
    Jul 19 2008
    united states
    Re: headlight mods
    the filing down of the shaft to make the new o-ring fit is what has me worried, with my mechanical expertise i'll probably end up ruining it,therefore causing a bigger expense.
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Re: headlight mods
    No filing is needed, just graphite powder.
    Even if you use silica gel packs, you'll still need to remove & open your headlights.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Long Island, NY
    Re: headlight mods
    That's right, no modification required. just slip on the larger o-rings . fixed.
    Jul 19 2008
    united states
    Re: headlight mods
    ok i went to lowes and got everything today,i'm gonna give it a whirl tomorrow!!
    Jul 19 2008
    united states
    Re: headlight mods
    ok it's finished,but if this doesn't fix the problem are there any aftermarket housings that are not vented that will fit on the car without having to change anything?
    Jul 10 2007
    trunk
    Re: headlight mods
    Did you use a bigger o-ring or add the silica gel packs?
    Stage 0 minus - .5
    Jul 19 2008
    united states
    Re: headlight mods
    # 6 o-ring
    Jul 10 2007
    trunk
    Re: headlight mods
    ^ I couldn't find a #6 o-ring up here (I don't know the size comparison between stock & #6), so I bought some assorted ones & sized up from the stock one where it was snug but the shaft could still turn.
    Stage 0 minus - .5
