If you would like to see the first satisfied group buy: Go Here!!
If you would like to see the second satisfied group buy: Go Here!!
If you would like to see the third satisfied group buy: Go Here!!
If you would like to see the fourth satisfied group buy: Go Here!!
As usual the sway kits include everything you need to bolt it right up, no welding, etc. The factory sway is 22mm which makes a big difference from the facoty 16mm or Sline 20mm rear sway. Comes with new oiled bushings. You re-use your factory brackets and hardware. A great upgrade for your B6/B7 A4/S4!! Larger RS4 brackets are available for $22 more! They are not required for the install however can make it go more smoothly.
Sways/Bushings/Brackets are fully in stock! Ships w/o any delay!
1. virgsa4 (Virgil M)
2. eweu (Matt S)
3. BigMig09 (Michael W.)
4. covertS4driver (Chris)
5. (Lawrence L)
6. Brent27 (Brent)
7. Chapunki (Matt Z.)
8. starfriend (Trond from Norway!)
9. Patate (Pat)
10. Kid Red (Rick L.)
11. prayforsnow247 (Chris C)
12. sickspeed (Brian M)
13. Frey7190 (James F)
14. cjonesgo (Corey J)
15. SunnyG (Sunny G!)
16. GeoFX (Milton K.)
17. darkness2505 (Dom)
18. surfnsail (Dave H.)
19. Joshua N.
20. B6Buckeye
21.
Price: $113 for Sways + Bushings (+$22 for brackets) = $135 + shipping!
Bracket update!!! To clear up some more confusion there are two brackets, even though our dealerships etka lists "8A0 as being the correct part number for the B7 RS4 "8E0-511-439-2ME" is the proper part for the larger bracket. 2ME is a chassis code for the B7 RS4 so that is the final word and I am sticking too it! We got an 8A0 in the shop here and from the looks of it (even tho our dealer etka says it is RS4 specific) it most definitely is not so were going to go with 8e0-511-439-2ME (so sorry for any further confusion) haha pm me w/any questions!
If you want to be added to the list you must e-mail me your:
Name
Billing/Shipping Address
CC Num/Exp Date
Contact phone/E-mail/AZ Handle
Cheers!
