Results 1 to 15 of 15
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    People with main bearing girdle. Any issues connecting the lower bell housing bolts?
    I spoke with my engine builder today and he was just finishing up machining the spacers to fit the main bearing girdle. He also said that it would lower the oil pan about a 1/4" . Are there going to be any issues connecting the oil pan to the bell housing?
    97 A4 2.0TQM
    Rochester, NY
    Re: People with main bearing girdle. Any issues connecting the lower bell housing bol
    I don't have a girdle, but that would definitely throw it off. I and many others did not put those bolts back in, they are a PITA to install/remove and I don't see how they help support anything.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Nope they won't line up, it's normal with a girdle. That's how mine is, as well.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    That 1/4 inch might bring the pan awfully close to the subframe.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Established Member Two Rings STASIK A4's Avatar
    Sep 28 2004
    Audi A4 1.8 Turbo Quattro
    Melbourne Australia
    Mine didnt line up..... but i took some time and made them line up...
    "I don't intend to grow up there's no future in it"
    96 B5 A4 Quattro
    2.0l GT25 440HP powered by Autronic SM2 with CDI 750cc injectors Walbro intank Bosch 044 external fuel pumps
    B5 S4 6Spd Drive train, Porsche 996 Front brakes over S4 rotors, PWR Custom FMIC, PWR Custom Power Steering Cooler, PWR Custom Gear Box Cooler, Tilton Gear Box Cooler Pump Ect.....
    Drive Fast Drive Safe Never ending Modding
    Oct 06 2004
    Minnesota
    You will need to cut room for the bolts. I have already tried
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Feb 13 2007
    98 A4
    Chicago
    I remember that they were pretty much impossible to remove unless I had an offset wrench.
    So whats the consensus? Cut to make room or just leave them out?
    Sep 28 2004
    Melbourne Australia
    Quote Originally Posted by 1NaudiA4 View Post
    Cut more room.... its only 3 you have to do....
    96 B5 A4 Quattro
    Active Member Two Rings HORROR BUSINESS's Avatar
    Apr 19 2008
    Clapped out Quattro on Air
    Those bolts are hell. I left them out
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Those bolts are easy to get to, undo the motor mounts (1 nut on each mount) and just jack up your engine a few inches and there is tons of room to get to those bottom bolts.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Sep 24 2005
    always in design
    Quote Originally Posted by A4 TSCHUSS View Post
    Not when running a girdle. It's not a 1/8" drop of the pan it's about a 1/2" and you go talk to anyone who's built one with a girdle, they don't line up.
    Apr 24 2005
    E55 AMG, CTS-V
    im not talking about bolts lineing up. They were saying those bottom bolts are hard to get to which they are extremely hard if you dont jack up your engine. If you do what I said then you could have like 4" down there to play with if you wanted.
    ~David~
    CTS-V 9.6@148
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Ok,
    the girdle lowers the oil pan a 1/4".Nothing else is affected so simply get a drill and machine out the holes a 1/4" moving upwards towards the hood of the car.I have done this about 4 times now.You will also need to machine the oil pan to clearance the 2 rear main stud nuts.
    http://forums.vwvortex.com/zerothread?id=3335766&page=5
    Feb 13 2007
    98 A4
    Chicago
    Quote Originally Posted by Issam@034 View Post
    Ok,
    Are you sure I'm going to need to have the oil pan clearanced for the 2 rear main stud nuts? It looks like thats not an AEB oil pan on that thread in vortex.
    Sep 28 2004
    Melbourne Australia
    Depends on how thick the walls of the sump are around the 2 bolts location you might end up with 2 holes there and then you will need to get the area around there welded back up and start again.... I had to do that as i found out, not a big deal but i wasnt happy at the time.. but its all about tial and error and learning things...
    96 B5 A4 Quattro
