Results 1 to 10 of 10
    Nov 12 2007
    Grand Junction, CO
    Is Up Shifting w/out Clutch Bad?
    I've heard from a few different people that you shift up to a higher gear w/out the clutch as long as the engine is at a higher RPM in the lower gear than you will need in the higher gear. Is that bad for the transmission, even if its done right?
    I know this may look like a stupid question....
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    Re: Is Up Shifting w/out Clutch Bad?
    Ive done it, on a fwd car, but i mean i wouldnt be doin it with no audi. Specially a Quattro.. It could turn bad... gettin it out of gear would be eazy but matchin that syncro would be a lil harder and if your jamin the thing... then youll har some grindage...
    But ive done it, goin about 80 with the revs up... Im guessin over time it will screw the tranny over. Grind the syncros down... i wouldnt be doin it.. Inless you have some high powered rocket and time matters
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    My step dad used to do this in his Rodeo, aka speed shifting, and no it isn't a good idea.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Ive done it but its usually not a good idea, cause if you fuck up your transmission is done-ski
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    Probably not a good idea on a car with synchro trans. Its fine to do this on a car with a competition gear box with straight cut gears.
    2007 A4 2.0T quattro Tip S-Line Titanium / Lava Gray / APR 91 /
    Apr 06 2007
    Arcadia, CA
    learn to do heel-&-toe!
    It's not that hard.
    07 B7 A4 Quattro Manual Sline.
    APR Software | Ecodetuning Testpipe | Milltek Exhaust
    RS4 Rear Sway Bar | ECS Snub Mount | AWE Boost Gauge
    Forge DV | PSS9 Coilover | Hartmann RS4 Replica with Falken 452
    Senior Member Two Rings UrKurt's Avatar
    Sep 01 2007
    1990 325is, 2008 A4 2.0t
    California
    Quote Originally Posted by edkwok View Post
    It's not that hard.
    OP's question regards upshifting.
    Mar 29 2006
    99.5 A4
    Ypsilanti, MI
    If you match the engine speed and transmission speed, you can do this upshift without any damage to your syncros. The problem is, it's not something just anyone can do - it take practice and until you are good at it, it will put accelerated wear on your syncos.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by quattro.it View Post
    ahhh why wasn't DSG an option for us... i want to trade in my B7 for a used SMG M3... lol... chill... just a temporary thought.
    Nov 12 2007
    Grand Junction, CO
    I've tried it. It comes out of gear easily. The hard part is getting it to fall into gear. There's is only a split deco d where it will go. If you miss...it grinds
