Originally Posted by
AK1RA07
How do we choose? Please someone correct me where I'm wrong.
For ease I will just divide the engine in half and analize 1 turbo.. so a 1.35L motor with one turbo..
1.35L = .047 cubic ft.
1 lb/min = 14.27cfm
Assuming this volume is displaced once per revolution... ( rpm x .047 )
That's what one would think, but we have 4 stroke engines.
suck :
squish :---- 1 revolution
bang :
blow :---- 2 revolutions
This means that your 1.35L engine is ingesting air only every other revolution.
AK1RA07
@ 3000 rpm = 141 cfm or 9.8 lb/min
@ 4000 rpm = 188 cfm or 13.17 lb/min
@ 5000 rpm = 235 cfm or 16.46 lb/min
@ 6000 rpm = 282 cfm or 19.76 lb/min
@ 7000 rpm = 329 cfm or 23.05 lb/min
So that makes the above lb/min figures twice as high as they really are.
BUT, those numbers are still for a normally aspirated engine. To get the air flow, you have to multiply the normally aspirated flow rate by the density ratio.
Density ratio is pressure ratio minus the losses due to turbo heating the air and intercooler pressure drop and intercooler inefficiency.
Pressure ratio is (at sea level) the absolute pressure in bar that you want to run.
To simplify things, let's assume you have a perfect intercooler (no pressure drop and 100% efficiency). Let's also assume you want 15psi boost (a pressure ratio of 2).
This mean that your density ratio is also 2.
So, NOW your calculated air flow table is correct for 15psi boost.
For the GT25, it shows it can push 15psi in a range of about 9-27 lb/min, most happily around 20lb/min. (just look across the pressure ratio 2 line). Or, from around 3000rpm to 8000rpm.
For the GT28, it can push 15psi from about 11lb/min to 37lb/min, most happily in the 22-27lb/min range. Or, from about 3400rpm upward.
Of course, these are theoretical, but are in the ballpark, if a little optimistic.
Based on the above, you can rethink what you've asked below. I think your questions will change a bit!!
AK1RA07
To flow the turbo to its max capacity... ( turbo cfm / .047 = rpm? )
K03 turbo rated at 283 cfm would be at 6021 RPM
K04 turbo rated at 370 cfm would be at 7872 RPM
GT25 turbo rated at 408 cfm would be at 8680 RPM
GT28 turbo rated at 448 cfm would be at 9531 RPM
So first off, why would a K03 ever be an option for this car if it can rev beyond 6000 RPM? Sure, the turbo should never see this because the engine is not perfectly efficent, nor is the turbo.. but still its close, and we all know its weaksauce cause we run more boost and blow them
I don't have maps for these off hand..
So .. better idea:
Looking at a compressor map for say a GT2554:
Its greatest efficency island seems to be around a PR of 1.4 (~6psi boost) and 13 lb/min (~4000 RPM on our motor) and range to a PR of 2.0 (14.7 psi boost) and 21 lbs/min (~6400 RPM on our motor) which might equate to a total of 390hp at that RPM. ( assuming 1hp equates to .108cfm x 2 turbos) This turbo seems ideal and you could obviously run more boost and make more power to redline. This setup seems pretty good.. so..
Why would we run a GT2860RS on a stock displacement motor?
Seems its range is about a PR of 1.5 ( ~7.35psi of boost ) to 2.3 (~19psi of boost) but at 17lb/min (about 5160RPM) to 28 lb/min (about 8500rpm) Sure there is the potential to make more power ( ~520hp @8500rpm
), but it seems like it would require more boost and take longer to make it..assuming we could safely rev to 8500rpm..
Is there any turbo size in between these two? Am I calculating this correctly? Anything else I should be considering?
The efficiency islands of these turbos don't have the same scales. To accurately compare the GT28 to the GT25, I would suggest using the same compressor efficiency as your guide.
For the GT25 the most efficient area appears to be 72%.
For the GT28, 72% or better is PR 1.2 at 9-12lb/min to PR 2.4 @34lb/min - PR 2.6 @25lb/min
Hope this helped!
