Originally Posted by
biketsai
How mmuch was the valve body and install difficulty? Does it also allow for more hP?
The install was a little more difficult than a trans fluid & filter change.
You have to drop the pan then the valve body. Which, when you are working on your back, is heavy. Other than the 20 something torx screws, 2 connectors, and the additional trans fluid it is not difficult. It was about an 8 liter fill once the VB was dropped.
L 10 said yes the car would handle more hp. The shifts are far better than they ever where without the VB and with or without the GIAC tip chip.
As I said in a previous post (a few years ago) the tip chip will change the shift times electronically some times but mechanically the shifts are still slow. The VB mechanically makes the shifts happen faster all the time.
