Results 1 to 6 of 6
Thread: new alternator
    Mar 26 2008
    Warwick,NY
    new alternator
    i have a 99 2.8 quattro a4, the shop said it takes 3 hours to install and its a 300 doller part, is this to high on the time to install and i know its to high on the price , right? so they said the total job is about 500, getting overcharged?
    Senior Member Three Rings BaconBait's Avatar
    Feb 17 2006
    In my car with a shotgun
    Re: new alternator
    Ouch. Did you go to a dealer or something?
    You can get a used and tested 120 amp alternator off www.car-part.com for $100. You may want to try another shop and ask them if it's okay to source your own alternator.
    -Craig
    Built: 2.0L Stage 4 3/4%
    Apr 01 2005
    one wagon one truck
    Michigan
    Re: new alternator
    Part is overpriced and the time seems a little on the long side. I would call a couple other shops and see what they say almost sounds like dealer charges.
    Dec 05 2007
    Re: new alternator
    The part is not overpriced, as that is about how much they go for brand new (even more). Refurbished/remanufactured/rebuilt ones of course is cheaper (maybe $150 plus core charge till you send back your old one) and you can get a used one for even cheaper. But the labor should be 3 hours for a beginner such as myself. Maybe an hour and half job tops (if done by mechanic). You would also need to find out if the one currently in your car is a Bosch or Valeo as the fitment will be different upon install (you need to order correct part). You will have either a 90 or 120 amp alternator.
    My suggestion is to order the Bentley Manual (you will be happy you got this book later on) and do the job yourself. You can save yourself maybe $300+.
    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    Re: new alternator
    First, how do you KNOW your alternator needs replaced?
    Have you went to Advanced/Pep Boys and asked someone to test it?
    I'd make sure your alternator really needs replaced before going any farther.
    If it DOES require ROR, $500 is outright rape, Even $300 is too much...
    And I say you don't need a Bentley manual. That's a waste of $70+ for elementary info which you can find yourself for free.
    Get a new alternator (or used one from a reputable source) and change the damned thing out.
    I'm relatively new to Audi's, and just did a full timing belt service on mine in less than 3 hours. This is by FAR the nicest and EASIEST car I have ever worked on, and once you begin to turn a couple wrenches (and that's about all you need -a MINIMAL amount of tools are needed to work on these) you'll see how right I am.
    Tell you what, If you know for sure the alt. is the culprit, PM me a number and best time to call, and I'll walk you through it over the phone.
    I just crushed a finger on a machine at work last week, and have lots of time on my hands (or what's left of 'em )
    Best wishes
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: new alternator
    is the car drivable? if it is and you're willing to drive down to the bronx, pm me. just bring the part and some pizza/beer and the both of us will get it done.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
