Originally Posted by
jaybquick@JHM
Glad to hear. Better results than expected on a newer car!!
Also glad to help out on the install with tech help and a diagram.
My car has nearly 80K miles on it. So my OEM bushing might have been getting a little worn. But when I inspected the OEM bushing after removal it looked to still be in pretty decent shape. If I had to guess I think the elimination of the clunk is due more to the stiffer/better Apikol bushing in general and not because my OEM bushing was worn out. The OEM bushing was working fine as designed, it's just an inferior (soft) bushing. I would imagine the elimination of my clunk would have occurred with 80K on the clock or 40K on the clock. I can't be sure though as I haven't owned the car very long so I'm not sure how long it has been clunking on hard shifts.
I know from experience on Subarus when I've done mods to eliminate rear diff clunk there have been increase in NVH (rear diff noise increased on one car and humming at certain RPMs occurred on another). Overall I'm very pleased with the mod especially considering the bushing is stiffer, yet there was not an increase in NVH. Perfect.
Let me try to explain how I did this.
Jason is right, the bolts required to do the removal/install are very easy to locate. Somewhat hard to reach, but doable for a shade tree mechanic like myself...
Thought I would offer some insight as figuring out the right alignment/position for the rear diff is critical to getting the top through bolt out that holds the rear diff mount in place.
I removed the bottom three hex bolts on the diff mount (#8 on diagram). At that point, you take the nut off the through bolt (#9 on diagram) on top, but you will quickly realize you don't have enough clearance to slide that through bolt back toward the rear diff to get it out because it is a longer bolt and it runs into the diff.... So - this requires some adjustment of the rear diff. I couldn't get clearance to get the very top of the three hex bolts (#16 on diagram) out that attach the rear diff to the subframe crossmember. I could loosen it several turns, but then it will eventually run into part of the subframe cross member and you won't have enought room to get it out... So I screwed it mostly back in and left it somewhat loose at that point. I then lowered the rear diff as far as possible, and barely still did not have enough clearance as I was still barely running into the top of the diff with the through bolt trying to slide it back to remove it... If you can get your rear diff low enough at thsi point to remove the through bolt that's perfect - your install is almost done. Alas, I could not.
So I removed the bottom two hex bolts (bottom two bolts #16 - all three hex bolts form an equilateral triangle) attaching the rear diff to the subframe cross member. At that point I tried to jack up the rear diff as high as possible at the front of the diff in an effort to get enough angle to get to that top hex bolt on the subframe cross member... Drat - still not enough clearance even with the front of the rear diff at max height. I then lowered the front of the rear diff again and still barely did not have enough clearance to get that top through bolt to slide back/out.... So I decided to move the rear diff toward the passenger side of the car. This is possible with the bottom two hex bolts removed that attach the rear diff to the subframe cross member and the top attachment bolt loosened a couple threads. When you push the front portion of rear diff toward the passenger side of the car you will then finally have clearance to slide that dang top through bolt out that attaches the rear diff mount. Once that's out it's easy as pie. If you follow this method in my opinion it will save you time and effort as this is the easiest way (maybe only way) to get that install done short of cutting the through bolt attaching the rear diff mount on top.
Clear as mud? Get under there for your install and it will all make perfect sense.
Hope this post helps with mod info (review) and installation.
