Results 1 to 14 of 14
    Registered Member One Ring vitamin b5's Avatar
    May 18 2008
    1999.5 a4 2.8qm black
    kent wa
    newbie question...brakes
    im sure someone has the info i need... basically im gettin s4 front brakes(caliper and rotors w pads) and rear rotors for next to free... what rear caliper can i use on the rear s4 rotors? is the a6(c4-c5) rear calipers the same as the b5 s4? or what can i do? thanks in advance for any info...
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Re: newbie question...brakes
    Quote Originally Posted by vitamin b5 View Post
    the front calipers and rotors WILL NOT work for you unless you purchase s4 uprights, they WILL NOT fit your a4 uprights. As far as the rear i believe you can use the s4 calipers with an aftermarket carrier and a6 rotors. and i just seen you said you arent getting the rear calipers so basically everything your getting is useless 4 you........
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Veteran Member Three Rings xraycer2012's Avatar
    May 28 2008
    B8.5 S4
    That stuff won't really help you. The usual brake upgrade is TT carriers, A8 Rotors and stock A4 calipers for the front, and S4 rotors calipers and carriers for the back.
    ‘23 RS6
    '14 S4 Nogaro Special Edition - Sold
    May 18 2008
    kent wa
    ^^^^^ thanks for all the info guys... i really appreciate it... looks like i may be goin the tt/a8 swap then...
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    You can sell decent S4 calipers for about 200 bucks. That is all the good they will do for you.
    Jim
    I Do Werk.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I did the A8 rotor swap recently and it feels soo much better already! Definitely worth it.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Established Member Two Rings Tigu's Avatar
    Sep 05 2008
    a4 MK1, Octavia II
    Hellinn Talsinki
    Quote Originally Posted by biketsai View Post
    Can you tell please wich MY A8 parts were used???
    and the TT parts also.
    and how did the old caliper was mounted on a 30mm thick rotor???
    when I installed new rotors and pads on the front they barely fit original 25mm rotor.
    so any detailed infos would be nice.
    May 28 2008
    B8.5 S4
    Get your TT Caliper Carriers here:
    http://www.parts4vws.com/catalog/pro...ber=8N0615125A
    Get your rotors from Adam@SPP:
    http://www.audizine.com/forum/showthread.php?t=186185
    Then get whatever pads you want. I got Hawk HPS Pads from ECS Tuning.
    ‘23 RS6
    Sep 05 2008
    a4 MK1, Octavia II
    Hellinn Talsinki
    hahahaaa
    lol,
    thanks for the tipps anyhow,
    got down the scrapyards to loog for some parts thou.
    I'm situated in europe.
    would try this setting whith some good used parts at first and then try some new if its neccesary.
    Sep 05 2008
    a4 MK1, Octavia II
    Hellinn Talsinki
    is there any particular problem why I can't upload a picture for my personal image???
    does it have to be some strikt size?
    or am aa dooing something wrong?
    Sep 01 2005
    Quote Originally Posted by xraycer2012 View Post
    no way go to www.purems.com. way cheaper
    Sep 05 2008
    a4 MK1, Octavia II
    Hellinn Talsinki
    http://www.purems.com/products/product.php/II=810
    sorry to see that things like that are so cheap in states.
    in europe the same parts cost about 550 dollars.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Better deal on 312x25mm rotors
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Forum Moderator Four Rings docurley's Avatar
    UK London
    This is my thread on RS4/S4 brakes
    http://www.audizine.com/forum/showth...ght=rs4+brakes
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
