Results 1 to 11 of 11
    Established Member Two Rings jsizzle20's Avatar
    Jun 01 2008
    2005 S4
    important question!?!?!
    I just accidentally filled up on 87 octane.......like a full tank. How bad is that going to be for the engine? If its really bad is there anything I can do to fix it?
    05 S4
    Unitronic, ECS tuning snub mount, E-Code Headlights, Blackout Grills.......more to come
    Veteran Member Four Rings boravr6's Avatar
    Aug 14 2008
    09 CTS-V
    Ontario
    Re: important question!?!?!
    i would not think 1 tank will hurt it. If you put diesel in it that would be a whole other story. If that ever happens.. dont even start the engine to move off the pumps!! just let the towing get it and have the tank drained.
    Worst case you can drop some octane boost in your tank. 5 points octane goes for like 10$ that will bring it up to 92 and set your mind at ease.
    ** Proud to support **
    JHMotorsports
    AUDI Revolution
    ~ 2009 Blue Diamond Tricoat CTS-V
    ~ 2006 TD1 Imola B7 S4 sedan 6MT *SOLD*
    ~ 2004 Silver B6 S4 sedan 6MT *SOLD*
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    My guess is that one tank won't hurt. You'll probably notice a reduction in power since the ECU will retard the timing to keep the engine from pinging. I wouldn't drive it especially hard either, keeping the engine temps down will reduce chances of pinging.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Yeah, dont push your engine... You can wait for a bit, like a 3/4 tank and fill it up with a high octane gas.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    Quote Originally Posted by aaaudiprotein View Post
    like 100 octane...
    $8.99 per gallon gas FTW
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    I would just buy a bottle of octane boost and dump it in.
    Dec 26 2007
    1999 Panoz AIV roadster
    New Market, MD
    Stay away from heavy engines loads and WOT. Forget the 104 Octane and similar stuff. The points they reference are 0.1 octane points. The only things that really work are things like Torco Mach Accelerator race fuel concentrate. Just take it easy and you should be fine but you'll feel better adding 1/3 to 1/2 tank of high octane as soon as you can.
    http://torcoracefuels.com/content/view/103/40/
    1999 Panoz AIV
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    It wont hurt it at all.. here let me show you guys something interesting..
    http://www.nytimes.com/2008/08/03/au...al&oref=slogin
    Its an interesting read on octanes and German cars.
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    you're fine. i read an article by porsche that said it's fine as well. the enginners realize that high octane fuel is not always available.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by boravr6 View Post
    Uh, don't give out information when you don't know what you are talking about. To raise your octane from 87 to 92, you will need to raise it by 50 points. Tossing in a bottle of 5 point octane boost will raise your 87 octane to 87.5 octane, not 92.
    FOR THE RECORD: 10 octane points is equal to 1 octane.
    Drive the car and keep putting super in it. Your octane will rise. also, don't race it to where the computer knock sensor goes into action and you'll be fine.
    Jun 01 2008
    2005 S4
    Thanks for all the info guys!!! When I looked down an saw that it was regular that I just filed up with I almost sh*t a brick......
    05 S4
