Results 1 to 6 of 6
    Jun 20 2007
    Colorado
    Sport springs with stock non sport shocks?
    Would this work? I'm probably going to end up getting the sport springs and using an aftermarket shock but just wanted to know. Thanks in advance!
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Re: Sport springs with stock non sport shocks?
    It would work, but not for long (usually less than a year). Upgrade both at the same time.
    USP CLUB MEMBER #34
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    2x
    Veteran Member Three Rings HamidsVikes's Avatar
    Jan 10 2008
    Vancouver, BC
    I ran with the stock shocks for about a year... when they dies, they died fast...
    I recommend doing them at the same time, you will save $$$ on instalation, and the ride is soooo much better with proper shocks!
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Everythings is said!
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Jun 20 2007
    Colorado
    sweet thanks guys. I found a used set for a little under 400 shipped. It's going on the wife's car so I really don't want to half ass it and hear about it
