Thread: Coolant Leak
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    Coolant Leak
    Okay i got a 2003 1.8t and i had a coolant leak before. I took it to a shop and they had fixed it for a pretty penny Coolant Flange. Now it seems i have a leak again on the right side of the engine facing it. the coolant seems to flow out after i have the car run for a few minutes but if the car isnt on it dosent seem to leak almost nothing like dripdrip. Any insight.
    Veteran Member Two Rings Nikon44's Avatar
    Mar 04 2004
    14 Ford F-150 FX4; 02 A4 1.8TQM; 04 Silv
    Alaska
    Re: Coolant Leak
    By right side are you talking intake mani side? If so it could be the Thermal Coolant Plug.
    Sean
    2002 1.8TQM
    Ecode Headlights - APR Stage 1 - Forge 007 (Green Spring) - AWE Boost Gauge - 15% Tint - 034 Motorsports Breather Hose Kit
    Waiting to be Installed
    Aprikol Snub - RS4 Engine Mounts - Vogtland Coilovers - RS4 Rear Sway Bar
    On Order
    Rims/Tires
    Mar 20 2008
    south
    Re: Coolant Leak
    yes it is on the intake manifold side. IT seems to be coming out from underneath the injectors or somewhere in that general area i can find the exact spot.
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    Re: Coolant Leak
    thermostat, or there is a plug that plugs into the side of the housing on the block for the thermostat that can start to leak.
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Re: Coolant Leak
    phew I just had a coolant leak as well, dealer said it was also the coolant flange. Thank god for warranty, and 50 dollar deductable. Hope you find it !
