Results 1 to 6 of 6
    Established Member Two Rings black_bi-turbo's Avatar
    Sep 23 2006
    2004 S4 Avant, BMW Z4
    Sarasota, FL.
    Problems again with Vredestein
    Just as an fyi for you all, i had another one of my ultracs, a new one i got a few months ago to replace the last one, blow out on the sidewall . Thankfully i was parked, checking tire pressures when it did so. I posted a few months back about the problems i was having with them and the company i bought the wheels from or vredestein not wanting to cover the tires. They claimed it was a road hazard issue, which it clearly is not. Just want vent and let you all know.
    Stay away from these tires!
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    Re: Problems again with Vredestein
    i kept hearing good things about these tires. i was going to get them as my next set of tires. thanks for the info.
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Thanks for the info. Are you going to try to get them to warranty replace this one? Or are done with these tires altogether?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    I haven't had any problems with mine. Great performance tire.
    Sep 23 2006
    Sarasota, FL.
    Definately done with these tires. Tried warrantying them last time, and they said it was due to underinflation and road hazard and they wouldn't cover it. That's 3 tires total i have had to replace. Two that blew out and one with a cracking sidewall.
    Just ordered a set of the sumitomo's for my 17's
