Results 1 to 25 of 25
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    Alcon 13" mono6 VS Stoptech 332 ST40
    I need to know specifically which caliper is thinner and provides more wheel clearance, the Stoptech 332 ST40 setup or the Alcon 13" mono6 Motorsport setup. I printed both templates and the stoptech seems to be thinner but I was always told the Alcon provided more wheel clearance? Is this only on their mono4 tracksports brakes?
    Anyone with real world experience in switching from either brand?
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Re: Alcon 13" mono6 VS Stoptech 332 ST40
    I'd pick the Alcon's over the Stoptech and get new wheels instead or run a small spacer instead. They're that much better.
    Feb 14 2004
    Michigan
    Thaks for the reply, I was waiting when you'd chime in. I have CCW classics and they supplied a 13mm spacer to clear a Stoptech 332 kit...The Alcon Mono6 is very tempting as it's a 6 piston 13" kit. Should have great pedal feel but I just can't sell my wheels
    With the 13mm spacer on there I have ALOT of room so idk...
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Untrue Stoptechs have more clearance.... you can fit them under 17's where that is not possible for Alcons.. pretty sure you must run a 18 or larger rim at all times.... Stoptechs also have many more brakes pad options...
    I was actually going to buy Alcons as they are awesome brakes, but most poeple including myself will never push them limits on a BBK... with the price diffrence and more wheel and pad options I went Stoptech.
    789whp
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Quote Originally Posted by Howard Hughes View Post
    The 13" Alcon kit does fit under a lot of 17" wheels.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Nov 09 2006
    08 cooper S, 97 C4S, 95 C4
    Tacoma, WA
    Not to get into it, but the Alcon is in another league over the Stoptechs. I would always suggest a monoblock caliper.
    Brembo also has good clearances with the smaller kits, they can fit stock 17in wheels.
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Where did you hear this?
    Best thing to do for each application is use the brake kit template to ensure a kit will fit behind your wheel.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    The Alcon calipers are hella smaller than the Stoptech units.
    You can't really compare them as they are two totally different calipers.
    You might want to run the Mono4 caliper as the A4 master brake cylinder might be too small to activate the Mono6 one.
    That's what I was told anyway
    May 27 2004
    Portland, OR
    Quote Originally Posted by [email protected] View Post
    Correct.
    Jeremy Williams
    Active Member Two Rings Murre's Avatar
    Apr 13 2008
    -04 Audi A4 Avant 1.8TQ
    Kangasala, Finland
    If I want to use Mono6 calibersin my B6. What master brake cylinder I have to change to replace it...B6S4, B7S4 or B7RS4?
    USP CLUB MEMBER #121
    Jun 11 2005
    Vancouver, BC
    You would need to upgrade to the B6S4 MBC use the Mono6 setup.
    I have yet to overload the mono4 setup at any track day I have gone to so far... but with double the power output now I'm going to try again!
    May 27 2004
    Portland, OR
    I agree with Winston...I think you'll find the Mono4 setup to exceed most needs. It's truly incredible!
    Jeremy Williams
    Veteran Member Two Rings
    Feb 26 2004
    Pittsburgh, PA
    I ran Stoptech 332 brakes for 4 years/85k miles and replaced them with the Alcon 13"/328mm Mono6 brakes last March. Both calipers clear my stock 17" wheels (B5 S4) and my 18"x8" 35et BBS RS-GT wheels. However, I must run a 2mm spacer for my 17"x8" 35et BBS RC wheels to clear the Alcons.
    2001.5 Audi S4 - Pearl White - Stage 3
    2005 Audi S4 Cab - Sprint Blue
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Quote Originally Posted by EricPA View Post
    The Stoptech's only clear the stock Avus wheels by about a millimeter or two anyway. It sounds like the Alcons are a hair wider (or at least a few millimeters more outboard). OP if you have 13mm spacers, check the clearance with the Stoptechs by finding a local owner and measure to see if the Alcon's will fit.
    In my experience, Stoptech has incredible, amazing customer service but their product is not top quality when compared to the Brembo and Alcon parts. I had Stoptechs on my car for ~40,000 miles and had have the following replaced under warranty: One set of calipers, two sets of brackets, and two sets of rotor hats/pins. On top of that I had to buy two sets of rotor rings and all new hardware (not cheap) and a rebuild kit. This was over the course of probably 15 track days and regular street driving (including winter). Stoptech was immensely helpful with the warranty and I can't say enough about their customer service... but when I buy another BBK it'll be a brembo kit. I still have my Stoptech calipers in my garage collecting dust because they are in such bad condition Im honestly afraid to use them and won't sell them in that condition. Maybe this would have happened to any set of brakes... maybe not. Maybe stoptech uses different alloys or anodization now to help protect the aluminum, maybe not. What I do know is that 40,000 miles was a damn short time to go through three sets of rotors and two sets of everything else.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    May 27 2004
    Portland, OR
    Do you think the spacer is needed due to the Mono6 caliper?
    Jeremy Williams
    Feb 26 2004
    Pittsburgh, PA
    Quote Originally Posted by jeremy@matrix View Post
    100% yes. I never have any issues with the 17" RCs while running ST-40/332 Stoptech brakes.
    However, I must say the clearance is sooooo close with the Mono6/328 Alcons. Meaning the back of the RC wheel just barely makes contact with the corner of the large piston on the caliper. Heck a 1mm spacer might be enough to make it clear. :-)
    May 27 2004
    Portland, OR
    Ok, good info. So a STaSIS/Alcon Mono4 caliper would have no issues with your RC's then?
    The reason I ask is that from what we've seen, usually the STaSIS/Alcon's narrower fitment (vs Stoptech for example) means that more wheels fit without issue.
    Jeremy Williams
    Feb 26 2004
    Pittsburgh, PA
    Yes Sir, the Mono4 would be fine.
    Registered Member Two Rings Jim@STaSIS's Avatar
    Sep 22 2008
    sonoma, ca
    Well I was hoping to shed a little light here, but lots of good information already contributed. Thanks all!
    May 27 2004
    Portland, OR
    Quote Originally Posted by Jim@STaSIS View Post
    Shed it Jimbo!
    Jeremy Williams
    Jun 14 2005
    Anaheim, CA
    Definitely. We always do that just in case!
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Sep 22 2008
    sonoma, ca
    Shed it Jimbo!
    So much light already shed! i am blinded by my uselessness!! =]
    May 27 2004
    Portland, OR
    So am I.
    Jeremy Williams
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    So let's say I already happen to have a set of Mono4 calipers. Is there anyone that sells the carriers and rotors/hats seperately? And does anyone know what these markings on the back of the calipers mean?
    M10x1 CAR9800 J57 04 B122
    -Tim
    May 27 2004
    Portland, OR
    Quote Originally Posted by sandspeed View Post
    I doubt Jason at STaSIS will sell you the other components but you can try; [email protected]
    Jeremy Williams
