Results 1 to 6 of 6
Thread: Foam Gun
    Aug 11 2008
    Washington
    Foam Gun
    So I just received the Foamaster II Quart foam gun thingy and I'm pretty special because I can't figure out how to use it. Can someone write up step by step instructions on how to fill it up/use it? I can't seem to get any decent amount of foam out of the thing. Nowhere even close to the picture on the DD website for example. I'm using adams car wash. Thanks!
    Art
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    Re: Foam Gun
    did you adjust the A, B, C, D setting up top? there is a table there to tell explain the setting. set it to C and you will get nice suds.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Aug 11 2008
    Washington
    Re: Foam Gun
    Yup got it. Had to pour the soap in then water then shake it up. I thought it would do the mixing but I got in now
    Nov 09 2005
    UBIQUITOUS
    Re: Foam Gun
    Quote Originally Posted by art1188 View Post
    i only put car wash in the bottle. water is mixed in thru the hose/nozzle.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Aug 11 2008
    Washington
    Re: Foam Gun
    Really? In the large container? And in the foam gun off the Detailers Domain site? I tried that but It definitely didn't work. Maybe you have a different foam gun?
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Foam Gun
    What soap are you using. Do you have a high PSI water hose?
    It wont be like the pictures on DD because they are using a pressure washer. Ill see if I can take a picture later.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
