Results 1 to 6 of 6
    Sep 10 2008
    Boston Ma
    Need answers about wheels size mods
    wheel 7.5jx17h2 ET45
    245/45 R17
    on a 02 Audi A4 quattro
    Should I use a 5mm spacer
    These wheels are from a 05 a6 quattro
    Will the rub???
    This is my wife and sons daily cummuter so safety is #1 to me. So if you are not 110% please don't waste my time.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Need answers about wheels size mods
    Didn't somebody already answer this for you in the main B6 forum?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Sep 10 2008
    Boston Ma
    Thanks
    May 03 2008
    Orlando
    Quote Originally Posted by jalib1 View Post
    Thanks
    Here you go:
    http://www.audizine.com/forum/showthread.php?t=234282
    You're welcome.
    Kevin W.
    Sep 10 2008
    Boston Ma
    He didn't seem to be 100%. I need reassuance
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Like I said, if you are looking to get the wheels flush, since ET 45 is definatly going to be sunken in, you will need more than the 5mm spacers. Those would bring you to ET 40 still sunken especially with 7.5 width wheels. That is why I mentioned 10mm spacers to bring you out to the normal ET 35 that people run on our cars.
    Here is a link to the Wheel & Tire forum I mentioned that should be able to have your question answered 110% by a vendor.
    http://www.audizine.com/forum/forumdisplay.php?f=12
    Here is a link to the Wheel spacers available and there options, ie hubcentric/ with lugnuts and what not to give you an idea of what you need.
    http://www.ecstuning.com/stage/edpd/...heel%20Spacers
    Good luck with getting that perfect stance.
