Results 1 to 15 of 15
    Senior Member Three Rings G-Bus's Avatar
    Aug 25 2008
    Montreal, Canada
    Removing master windows switch
    Hey,
    My master window switch had the child lock button broken, so people in the back couldn't roll down their windows. I pressed on it really hard yesturday and the whole swtich kind of "fell". How do I get to push it back up? Do I have to remove the whole door card or can I just remove the plastic thats kinda the whole door handle? I looked up for DIYs but couldn't find anything.
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    Re: Removing master windows switch
    Interested to know myself, mine is stuck down as well. It was like that when I bought the car
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Veteran Member Three Rings Pete4 1.8t's Avatar
    Jan 13 2007
    '12 328i Sport, Others: '12 A8L W12, '12 S5 Cab, '11 P. Cayenne, '13 P. 911 C2S
    Greensboro
    You probably have to take off the door panel and then see if any of the tabs that hold it up aren't broken off or something. The child lock in mine went out too, fortunately it was replaced underwarranty. They said something about it being a short in the switch or something.
    2003 Audi A4 1.8t 5-Speed
    Light Silver with Ebony Leather with Premium Package
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    You need to take off the whole door card.. mine was replaced under warranty as well.. it is around $150 bucks for the part and you get all new switches.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    You must remove the whole panel.
    I just find it funny that you were able to just accidently push the whole switch out....I spent maybe 2 hours once trying to get that damn switch out of its place with no luck!
    -Sami-
    Aug 25 2008
    Montreal, Canada
    Ohh man this blows. I don't want to remove the whole door card because I know that once put back, it'll start rattling from everywhere.
    Jun 08 2008
    Calgary AB Canada
    its not hard to remove the door trim, and no, it wont start retteling
    Aug 26 2005
    Quote Originally Posted by onceover View Post
    2nd that.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    If you plan on DIY on the switches, I recommend picking up a few of the quick clips that hold the card tight around the edges. You will more than likely break one or two when removing or reinstalling. They are like $2 bucks at the dealer.
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    i had the same problem. its not hard to remove door panel, do that, unscrew switch panel and look what is the problem. My wasnt staying down, when i took it i noticed that little spring hook wouldnt stay in the same place, so i just cut a little slit in it so it would catch it if you are gonna fix it yourself TAKE A LOT OF PICTURES and if you cant figure out post pics and im pretty sure somebody will come up with idea how to fix it. GL
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    it really wasnt that hard and mine doesnt rattle at all now, it did it twice
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Aug 25 2008
    Montreal, Canada
    Alright guys, I'm going to work on it now.
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    go to a4mods.com and look at the turbo timer companion lite install... i show how to pull the driver's door panel in that writeup
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Oct 02 2006
    MN
    ^w00t! A4Mods to the rescue once again!
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    I know right, that thing is in there fairly tight. You have to do a good amount of prying to get it to pop out. I don't know how people manage to push them out from the top. Unless ya'll are droppin' 'bows on 'em........................
