Results 1 to 15 of 15
    Senior Member Three Rings xx_s4quattro_xx's Avatar
    Mar 11 2008
    00 s4 and 00 bimmer 323ci
    san diego ca
    12pc silicone hose on ebay
    I know this has been brought up before But i just wanna know the updates. For those who bought them are they giving any problems? Are the ripping? Im thinking bout buying this its only 100 bucks. My upper intake hose is about to give and the dealer charge 88 bucks for just one. so please LMK the results thanks in advance heres the link
    http://cgi.ebay.com/ebaymotors/Audi-...ayphotohosting
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Re: 12pc silicone hose on ebay
    looks good from the picture, but I've never heard of "autobahn88" before, and I also tend to be weary of eBay stuff. I might be just fine, IDK. You can't beat that price, that's for sure!!
    I my favorite part is: "DIY in 60 min." Waaahaha, yeah right!
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Established Member Two Rings RenegadeEngr's Avatar
    Jun 15 2008
    San Francisco
    If you search a bit people on here have used this before. Everything is ok but the TBB...
    2001:Silver:S4:DarIntake:ABT Chip
    Mechanical/Fluids Engineer
    Mar 11 2008
    san diego ca
    well looks like these are going on the S then thanks for the reply gentlemans.
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Quote Originally Posted by BITRBO View Post
    You forget they're chinese! They have small everything, including their hands...this smallness allows them to get into those trademark tight Audi spaces.
    To the OP...search "EBAY SILICONE HOSES". On a different note, I currently use them and so far they're holding up. A little trimming goes along way on these parts...DO NOT USE THE F-HOSE or TBB hoses, they just suck!
    2015 B8 SQ5
    Click Here
    Past
    Mar 11 2008
    san diego ca
    Ha ha lol alright thanks for the tip.
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    I've had mine on for 9 months and no problems. i do use the samco TBB though, but ebay silicone everywhere else. i think it is a great deal.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    I have these and they work fine for me. I use the gangsta ebay/Chinese TBB and F-hose… it sucked to actually put everything in because of trimming (as mentioned before), but I bought the AWE hose clamps for these and tightened the f out of them… I also used some silicone grease to help slide a few pieces on. Definitely have a box cutter around and try to make straight cuts. I used this method on 2 cars so far that have no problems with the hoses (knock very hard on wood). I say go for it. If the f-hose and tbb fail, just get the samco ones later, but I would still use the ones from chiner. BTW, I’m running 19lbs on stock k03’s with test pipes and nothing blew off or ripped, so hopefully that tells you something.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    What's the point of buying them if the two most important hoses suck?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    May 18 2007
    Baytown, TX
    they're not bad. i just think people are worried about putting certain pieces on... but the silicone is thick as hell, so you should have to problems with it.
    Mar 11 2008
    san diego ca
    Quote Originally Posted by RedRocketS4 View Post
    Thanks.
    Senior Member Two Rings KryptoniK01's Avatar
    Nov 27 2006
    B5 S4
    Vancouver BC
    Same experience here with the autobahn88 hoses... good quality hoses but trimming required. TBB is suspect as mentioned (I'm not using mine either) and you need to trim the Y-Pipe/DV Hoses on the inside. My car doesn't have an F-Hose so I'm not using that hose either but the one I received looks fine visually so I'm not sure what issues Slow4 had with his.
    :: APR V5 :: GIAC Tip Chip :: AWE Boost Guage :: Apikol Rear Diff Mount :: 710N's ::
    Senior Member Three Rings AK1RA07's Avatar
    Dec 07 2007
    2001 S4, 1992 Miata, 1993 RX-7
    DFW
    I got a set of these for 100$ shipped (no name ones, not even Autobahn88) they look real good, and they're reinforced. I've only put on the TBB thus far, and it took some modifying.. it was too long on the largest side, the inside pipe stoppers had some 'casting flash' on it and and the boost sensor sits too high to use the engine cover.. but all these problems can be fixed with a knife and about 30 mins, and I've heard of people having similar problems with the Samco ones as well.. for the price, I still think it was worth it.
    Aug 06 2008
    Canadia
    I just finished installing mine yesterday (last hose was the one for the LH turbo, it was a total bitch to put on)
    the hoses for the intercoolers fit fine, no trimming needed, but the rest needed small tweaking.
    for the y-pipe ones, i wouldn't bother installing them, they rub on the front engine cover and don't fit well at all, looks pretty bad. other than that, go for it!
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by RolledMySTi View Post
    Because I had already replaced the OEM TBB with a Samco before buying the hoses.
    It just looked funny and I can only imagine what trimming I might have needed to do on the inside (its too small to fit anything in to trim).
    2015 B8 SQ5
    Click Here
    Past
