Results 1 to 20 of 20
    Dec 24 2007
    St. Pete,FL
    Bad Falken Tire...?
    i bought a set of falken tires when i put my wheels on maybe 3 months ago.....put air in my back tire this weekend bc it looked a little low....now all of a sudden the entire wheel has the most annoying vibration cruising....aggravated i went to the shop i bought them from and you could see it bubbled a little on the inside wear and they told me it was splitting from the inside?? idk i checked the pressure before and after and never maxed above 50psi like it says.....so now i buying a new one but my question really is do i buy 2 bc of quattro and wear issues etc.?
    Dec 25 2004
    Earth
    Re: Bad Falken Tire...?
    You realize how many different models and sizes of tires Falken makes?
    Could you be more specific? Falken...FK 452? St-115? Fk-912?
    What size?
    What rim width are they mounted on?
    How many miles on them?
    You should never inflate a street drive tire to its "max" pressure! The pressure will get higher as the tire gets hotter from normal driving! Always check tire pressure "cold".
    Most tire problems are a result of running over something, and the problem manifesting itself later on down the road, usually days or months after the fact...
    Dec 19 2007
    York, PA
    Quote Originally Posted by SmokdOutA4 View Post
    whered you purchase them from? I would warranty that shit.
    Dec 24 2007
    St. Pete,FL
    they are fk452's...225/35/19....maybe 5000 miles on them......they were barely warm.....really i am more concerned with whether i should buy 2 to compensate wear with the quattro or will it be ok with one?
    May 21 2007
    Florida
    haha holy shit youre one of those customers! just because a tire says "max 50psi" doesnt mean you want 50psi in your tire. our cars i believe are 32-34psi. bubbles are basically a seperation of the metal belts in the tire, which in no way is safe. they occur from hitting potholes and curbs. very rarely is it a manufatures defect. especially after 3 months at improper PSI. i would replace that tire ASAP. you can buy two if you want but 5k miles isnt much so i wouldnt think it would hurt anything. i doubt youve even worn 1/32nd off in 5k miles so tread should be practically the same.
    just a funny story:
    one day we had a customer come in with his brand new 2007 civic with just under 10k on it. he was all flustered and pissed off because he had just had a blowout on the highway. we went ahead and replaced the tire for him and i went ahead and checked the rest of the tire pressures. well, lets just say i found the reason for his blowout. 130PSI in each of the other 3 tires!!! lol wtf....thats 100psi over what factory recommendations are. some people....
    2018 Navarro Blue Q5
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Quote Originally Posted by doublezero30 View Post
    just a funny story:
    130 psi?!?!?!?! what was that guy thinking??? im a bit surprised that nothing happened to his other 3 tires....
    Dec 19 2007
    York, PA
    just a funny story:
    lol, hes going for good gas mileage...i bet the tires looked like this \/ on the ground
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    i didnt read it, but i heard my boss watching a video about EXPIRED tires. Some stores sell tires that were made 5-6 years ago and that would make tires unsafe, i think some commity did inspection and found lots of those tires are still selling. Maybe you got one of those extremely old tires. . .
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Quote Originally Posted by BOPOH View Post
    I don't think that is the case here, I don't think FK452's have been on the market for that long yet.
    Hey SmokdOut, you got the bubble from too much tire pressure, keep it around 35psi. Same thing happened to me on my all seasons last year, too much pressure, hit a pothole and got a bubble.
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    I don't see where he said he had it at 50. Only that he never took it past.................
    Veteran Member Three Rings CX-7&A4's Avatar
    Dec 08 2007
    CX-7 AWD/A4
    Foreclosure Captial of the US
    Falken tires usually have a warranty on them.
    07 Mazda CX-7 AWD
    06 Audi A4 Fail2Trak CVT - TRW Front/Mintex Redbox Rear
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Bad Falken Tire...?
    No falken way.... That's falked up.....
    Buh dump... dump.
    Thank you folks, don't forget to tip your waitress.
    My 2004.5 APR Stage 3+ is SOLD
    Dec 19 2007
    York, PA
    Quote Originally Posted by rxrep View Post
    Bad Falken Tire...?
    lulz, nice
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    I just orderd a set of 912's but I know quite a few people that ran them with no problems. even with strech.
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Could have been a factory defective tire, that does happen you know.
    Dec 25 2004
    Earth
    Quote Originally Posted by Kittrell View Post
    How you gonna prove it?
    Send it to the factory and have it examined?
    Most tire retailers are not "qualified" to examine a tire and determine its failure.
    I ran in to a simular problem with a set of Michilens once...
    The tire basically split in half!
    The place I bought'm from could only offer a replacement, but at pro-rated price.
    Yes, I bough the warrenty...
    I could of sent the tire to the Michilen lab, at my expense, and pay for the exam...
    If it turned out it was a manufac defect, they would still only replace with a pro-rate...
    The easiest, simplist. quickest, less-costly answer was to simply get another tire that day, and be back on the road in an hour.
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Shouldn't have to prove it. That is a shit warranty. If you bought your tires from Big O and got their road hazard warranty. They would replaced the tire for FREE. None of this pro rate BS. Any tire shop worth a shit would replace that tire at no charge if you opted for the warranty.
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    [/QUOTE]just a funny story:
    one day we had a customer come in with his brand new 2007 civic with just under 10k on it. he was all flustered and pissed off because he had just had a blowout on the highway. we went ahead and replaced the tire for him and i went ahead and checked the rest of the tire pressures. well, lets just say i found the reason for his blowout. 130PSI in each of the other 3 tires!!! lol wtf....thats 100psi over what factory recommendations are. some people....[/QUOTE]
    Lmao maybe he though he could go faster hahahahah what a tool.
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Dec 24 2007
    St. Pete,FL
    its whatev at this point im just tired of the shitty vibration......i got 1 new tire coming tomorrow and my guy said he would send it out to see if i could get a warranty deal out of it but for now its out of my pocket....idc i just wanna drive my car and from now on will run lowish tire pressure here in florida with all our damn pot holes
    thank you kittrell for reading my whole post where i never ran my tires at 50 psi......they were kept around 40 and are now at 36-37..............ignorance is bliss sometimes
    Dec 08 2007
    CX-7 AWD/A4
    They're probably not balancing them right, I have Falken Ziex tires on my CX-7 and they must be balanced without any weights, Big O Tire does it best.
    07 Mazda CX-7 AWD
