Results 1 to 8 of 8
    Veteran Member Three Rings A4Triple Blk's Avatar
    Jun 10 2008
    Past - 2004 A4 1.8T Quattro 6 Spd
    LI
    Wheel Problems ?
    I am looking at 18x8 usp rims off ebay http://http://cgi.ebay.com/ebaymotor...mZ280264729173 and i was at the shop talking to the guys that I would get the new tires and have them installed and they told me that getting a bigger rim would give me a much harder ride and my ball joints and front dent would go much earlier than expected. I know many of you have gone up in rim size. Has it affected any thing ride? ball joints or front dent ? if so how much should i get these rims ?
    B8 2011 A4 Premium+ 6 speed
    Used to B6 it
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Re: Wheel Problems ?
    I think you should get these rims because your car has he same suspension structure than a USP that comes with this wheel size. IMO This will not cause your ball joint or anything to break but you could expect a harder ride than with smaller rims...
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    May 21 2007
    Florida
    when getting bigger wheels, always expect a harsher ride. not really because of the bigger wheels, but the smaller tires you have to use to accomodate them. ive never heard anything about ball joints and such wearing faster? i mean, maybe it will put a bit more pressure on them...but if you stay as close as you can to the same rolling diameter as your stock wheels i think youll be fine. the speedo will be a bit off too, but not like that matters. our cars are set so when the speedo says 40 youre really doing 37. with my 19's my car is now at 1mph under what the speed says instead of 3.
    oh and your links not working.
    2018 Navarro Blue Q5
    Jun 10 2008
    LI
    ^^ i looked at your pics and the rims you have in you album the usp ones in the box those are the ones i'm looking to get from ebay and i really appreciate the help guys keep it comingg
    Used to B6 it
    May 21 2007
    Florida
    ohh those were b5 rs4 reps. those are my old wheels. those wheels are kinda heavy, but they are relatively strong. i saw a minimal change in on the speedo, maybe 1mph difference. seller ships them very fast though. i got them in 4 days i believe.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I've been rolling on 18x8.5 @ 26lbs a wheel for 40k with no adverse affects on my front end components.
    May 21 2007
    Florida
    ^tires will wear on the edges faster, thats about it..
    Jun 10 2008
    LI
    yea the ones i would be getting are 18x8
    Used to B6 it
