Results 1 to 20 of 20
    Registered Member Two Rings I Audi5K I's Avatar
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    Rear Window Regulator
    Does any one have a DIY that is not a glue fix or cut the door job. Just an actual DIY of how to replace the right rear window regulator. Any info would help, thanks!
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    | Revo Stage 1 | RNS-E | Racetec FMIC | Milltek Exhaust |
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    Re: Rear Window Regulator
    bump....??
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    Yea I found that one but like I said I was really looking for one that is not the glue fix. One that actually explains how to replace the rear window regulator. And if you notice in that DIY he cut the door with a dremel
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Yeah I'm not sure how to do it with out going that route.. I couldn't view the pictures on my comp at work. I have taken the rear door card off but didn't make note of how everything was attached...sorry I couldn't be of more help, perhaps someone else will chime in soon.
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    thanks for the effort though!
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    haha, man that thing is easy to fix!! i did mine pretty fast(once i figured it out) you can take out whole window frame and you will get all access you need. I have few pics how i did:
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    ^^nice...you got anymore pics or tips you would like to share?
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    Oct 08 2007
    Columbus, OH
    yeah man glad to help anyway i can
    my wi-fi sucks so it may take few minutes until my next reply with more pictures and few more details
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    thanks man....gonna tackle this Saturday, got to get it all done before College football...Thank god Ohio State doesn't play till 8 PM !!
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    Oct 08 2007
    Columbus, OH
    hey im from OHIO too, going to OSU next year, after im done with USMC. Im working on that write up for you right now, pictures load extremely slow
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    O....H....!!!!
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    Oct 08 2007
    Columbus, OH
    when you take off door panel you'll see this:
    take off center plastic panel and motor, not hard but screws are soft so be careful
    click on picture and you'll red circles these are the screws that hold window frame inplace, if it doesnt start moving freely i may forgat one. i did it like a year ago i think. once you pull it out CAREFULLY it should look like this
    remember that blue pentagon looking thingy position and where cable tubes are and what color, its VERY IMPORTANT they are different colors and length, there will be that blue pentagon looking thingy with white wheel in it, dont worry it has tight tension on it, but once you take it off you'll have alot of cable freed. when you replace it make sure there is no empty track present on that wheel.
    here is what broke on mine and how i fixed it
    i got nail made a grove in it for cable and placed it like this securing with zipties
    after that i filled it with EPOXY FOR PLASTIC on both sides and it worsk like a champ.
    Hope that helps, good luck on your project!!
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    would this work on the front window? from all pics i've seen there's only that blue piece in the front.. no green?
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Oct 08 2007
    Columbus, OH
    i had to fix REAR, but i dont see how front wont have green guiding brackit on it, maybe its different color and shape?
    Feb 24 2007
    Burlington, Vermont
    front...
    (sorry for thread jacking!)
    edit i'm blind.. its up at the top
    - Scott
    Das Build Thread
    Oct 08 2007
    Columbus, OH
    i c how it is, two guiders and one wheely thingy whats the problem?
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    nice perfect....that is exactly what I needed....kind wish I hadn't bought the regulator now but oh well.
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    Senior Member Three Rings Murf's Avatar
    May 19 2007
    02 Audi A4 1.8t quattro
    New Jersey
    I just wanted to thanks BOHOP. I had the same exact problem and your solution worked perfectly. Saved me a lot of money.
    2002 A4 1.8t 5speed
    STaSIS StreetSports | 19" Privat Reserv's | Pioneer AVIC D3 | Decorsa Street Exhaust | Boosted Tech CAI | | JHM Short Shift | Forge Splitter
    Oct 08 2007
    Columbus, OH
    Quote Originally Posted by Murf View Post
    glad to help
