I am about bleed my barkes, with Motul 5.1 I just put in stainless steel lines front and back. Should I bleed my clutch at the same time and also should I bleed my ABS pump? Where is the nipple located for the clutch slave cylinder if I have to bleed it, and also If I have to bleed the abs pump do i just run the system through vag-com or do I need to rebleed after I run it?
-Roman
