Results 1 to 18 of 18
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    headlight washer problem
    here is my problem, i already searched forum but found nothing relating to my problem.
    with headlights in the "off" position, by using washers, it works fine. I can get the water to shoot onto windshield and the wipers wipe away the washer fluid.
    with the headlights in the "on" position. the pump squirts a bit of washer fluid on the windshield, wipers activate, fuse pops and headlight washers never activiate. the fuse ALWAYS blows when i try to use the washers and the headlights are "on" if the headlights are "off" works fine everytime. its warm here in east coast still so i know the headlight washers aren't frozen to the bumper which can blow the fuse if you try to use them. i don't want to have to turn off my lights during the winter just to use my wipers when the salt/dirt/snow builds up on the windshield.
    so far i've gone through 13 fuses and i can't figure out why my headlight washers won't work and winter is around the corner. TIA for any insight or help!!
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Re: headlight washer problem
    You probably have a short somewhere in the headlight washer circuit.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Nov 25 2006
    Austin, TX
    thanks for the quick reply actlsub9, sh*t that sounds expensive! i have about 3 months left of the CPO warranty, you think it will be covered under that? imma try to find a DIY fix for this if not. hopefully someone can point me in the right direciton.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Headlight washers are covered under the CPO warranty, I had a leaky one replaced. Yours seem to be electrical so certainly covered... GL
    Jun 13 2005
    Audi
    If I had to guess it would definitely be covered under your CPO warranty.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Nov 25 2006
    Austin, TX
    nice, i'll be bringing this to the dealership! thanks everyone!
    Jun 10 2008
    sf
    are you using a 25a or a 30a fuse? the originally 25a fuse is wrong.
    Nov 25 2006
    Austin, TX
    i'm using the 25a fuse that it says to use on the fuse cover. i've been using that fuse for the past 2 years and it worked fine. only now i've had the problem with fuses blowing out all the time with the lights on. which fuse do you use? it won't void the warranty if you use a dif amp fuse will it?
    Jun 10 2008
    sf
    there is a spare 30a fuse in the box to the right. i learned this recently as i went a year with no wipers at all, replaced the fuse and voila!
    Nov 25 2006
    Austin, TX
    imma try this today after work, if that doesn't work, i gotta call the dealership to make an appt. thanks kaizr
    Jun 10 2008
    sf
    don't thank me, thank old guy. just paying it forward.
    Nov 25 2006
    Austin, TX
    that 30a fuse has been working great for the past week. no blown fuses!
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    At least your headlight washer works, mine never did.
    Nov 24 2006
    Burnaby
    hey, i have the same problem as you. i thought it was the windshield washer pump that went broke, but it wasn't. because when i took it all apart and replaced it, the problem was still there, and the headlight washers never fired.
    thing is, there's another pump in there, another bigger one. the one that powers the windshield is about cell phone size. the bigger one powers the headlamp washers (it's higher pressure spray). my next step would be to replace that. but for now, i'm thinking of just disconnecting the wiring to that big pump, because i never need the headlamp washers anyway. at least then i wouldn't have to turn off the lights to use the washers at night. just keep a few spare 25A fuses in the car in case you forget.
    hope that helps
    Jun 10 2008
    sf
    30a champdock 30a!
    Senior Member Three Rings 0330QA4's Avatar
    May 25 2007
    2009 VW CC Sport, 03 A4 (Sold)
    Ashburn Va
    Which fuse are you replacing with the 30a? Mine isnt blowing but I am getting nothing from my headlamp washers right now.
    Jun 08 2008
    Calgary AB Canada
    your guy's headlight washers work with the headlights in the off position? Mine only work when my headlights are on
    Nov 25 2006
    Austin, TX
    Quote Originally Posted by 0330QA4 View Post
    it's towards the bottom in the center row. but instead of using 25a i used a 30a
