Results 1 to 15 of 15
    Veteran Member Three Rings ubermidget's Avatar
    Dec 08 2006
    Boston, MA
    fuel pump for full rs6's??
    now im at the point of deciding on fueling.....
    gonna run an 85mm maf
    60#'s
    full rs6's
    Vast w/m
    stock motor so only around 24-25 psi
    dont really wanna spend $425 on the drop in 044.....any other options sufficient enough for my setup?
    EPL Stage 3 Aquamisted
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Re: fuel pump for full rs6's??
    Quote Originally Posted by ubermidget View Post
    60#'s
    full rs6's
    Vast w/m
    80.00 walbro 255gph u will never max it with those turbos/setup..............
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Where are you getting it for $80?
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Active Member Four Rings
    Dec 11 2006
    Boston
    You can find Walbro's for under 100 anywhere, google is your friend. Just make sure you get it from a reputable place.
    Mar 11 2008
    north east
    really. hmm that seems like a no brainer.
    is it just stupid to run your stock fuel pump on an rs6 kitt upgrade??
    stock motor. imagine its not a problem until your fuel pump becomes a problem. im just wondering on a dollar per gain comparison.
    Dec 11 2006
    Boston
    I would imagine the stock FP would be maxxed out with RS6's.
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    All ready have a dead walbro in my experience. Had to call the towing to get the s4 out of boulvard and scrach my front bumper b/c my car is too low. Hope the second one will last. Walbro is more than anough for your setup.
    Mar 14 2007
    michigan
    make sure u dont get the chinese knock off pump
    Registered Member Three Rings
    Aug 14 2008
    Salt Lake City, UT
    Get a bosch 044. Nothing will make you kick yourself in the head more then killing a $$$$ motor because you wanted to save a few bucks and bought an inferior pump.
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Oct 14 2007
    Val-Belair
    Quote Originally Posted by pete@integrated View Post
    SOOO right. I'll give this walbro a second chance and then put a 044 if it'll hapen again
    Mar 14 2007
    michigan
    there nothing wrong with the walbro as people have been running them for years upon years. Why spend an extra 400.00 if you dont need to
    Established Member Two Rings FunkWeasel's Avatar
    Mar 29 2004
    S4
    New Albany, Indiana
    Quote Originally Posted by generationjdm View Post
    Just get one with a warranty. I've installed quite a few of them here in NorCal and damned near half have gone bad. If they work, they flow just fine though. There'll be no real performance issue. fwiw JohnnyBravo (the TiAl turbo guy) sells the 044s for quite a bit cheaper, maybe contact him?
    Just my 2cents.
    Senior Member Two Rings u7401087's Avatar
    Feb 24 2006
    Indiana
    regarding to the bosch 044...
    034 offers "drop in" 044 fuel pump.....
    do we really need this? or regular 044 fuel pump will do the work?
    RS4 grill~custom widebody~M3 style lip~DTM Kreuz 10
    Dynaudio~Xtant~
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    no brainer you don't want that setup blowing up with a stock FP or even an RS4 fuel pump go 044 it's bad ass and you def won't run out of fuel with it.
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    May 16 2008
    South Texas
    Quote Originally Posted by deb38 View Post
    There are lots of Cheap Walbro chinese crap floating out there with the walbro name stamped on them.
    The best place at the best price to get Genuine walbro units I've found is this:
    http://www.autoperformanceengineering.com/
    The LT1 kit drops into a B5 pump cradle with the included foam sleeve and the included filter works great. It's a 30 minute job. I've done dozens.
