Results 1 to 15 of 15
    Veteran Member Three Rings TrboPowr's Avatar
    Nov 23 2005
    2007 A4 S-line Turbo, 2007 A6 Avant, 2010 Porsche Cayenne GTS
    Washington DC
    So my brake light keeps flashing....
    And Im clueless as to what it could be other then maybe low brake fluid??
    Can someone shed some light on the problem or share experiences? Thanks fellas!
    2007 RAI B7 BORG WARNER EFR
    Deval│Vorsteiner│Bilstein│Brembo│Oettinger│Borg Warner
    Mods = Bitch slap to my bank account
    May 20 2004
    More cars
    Never Land Ranch
    Re: So my brake light keeps flashing....
    are you getting the warning that looks like this (O) ?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Nov 23 2005
    Washington DC
    its the actual red light that says BRAKE on it, not on the LCD screen if thats what you mean... I just flashes and does the beeping sound 3 times
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    well u should fir have that warning "(O)"... indicating low brake fluid, then when it gets to the critical point, the brake light will startflashing. u probably need new pads/ rotors, or both... that was my case
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Three Rings 07audi4's Avatar
    Dec 06 2006
    2007 audi a4 2.0T quattro
    rochester, new york
    the same thing happened to me. i added brake fluid and it went away. just do a quick visual of the pads and rotors. usually when your pads start to go you will get the pad warning on the display.
    2007 AWE Tuning Audi A4 2.0T Quattro
    APR Stock 91 93 Race / Evolution Motorsports Intake / AWE Tuning Front Mount Intercooler / AWE Tuning Downpipe Back Exhaust / Neuspeed Race Springs / H&R S4 Front And Rear Sway Bars / Fog Light Mod / 10% Tint With Custom Audi Emblems In Rear Windows
    Jun 05 2007
    Phillips Ranch, CA
    x3 was happening to me for a while, I took it in to my dealer and they added brake fluid. Since then It has not happend again
    Veteran Member Three Rings A4twin's Avatar
    Jun 02 2007
    2016 SQ5 2021 VW Tiguan
    Pasadena, Tx
    Quote Originally Posted by TrboPowr View Post
    same here added some brake fluid haven't seen light since...
    2016 SQ5 APR OBD11
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    ^^ same deal here.. low brake fluid.. actual brake sensor was not going off
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    it doesnt mean low brake fluid. Adding break fluid may make the light stop, but its not correcting the problem. The problem is your rotors are getting thin...the computer is sending more than normal amounts of brake fluid to the breaks to compensate for the thin rotors which makes the light blink. Adding more brake fluid will temporarily correct the problem by confusing the computer into thinking the its not sending as much fluid to the brakes, but the real problem is the rotors. I had to replace mine on my B7 at 15k so not having a lot of miles doesnt mean anything....
    just my 2 cents
    Aug 08 2008
    2017 Q5
    Houston, TX
    man, thats good to know about the rotors. why do you think the rotors go so fast? I had the same rotors on my civic for 96k. had them resurfaced twice but thats it. the first time was after 60k and the last was around 90k.
    Jun 05 2007
    Phillips Ranch, CA
    rotors huh? I am using the same OEM brakes and rotors since purchasing the car 2 years back. I already have 39XXX miles now.
    Nov 23 2005
    Washington DC
    i got 55K miles on mine..... hey i like driving my whip ok? backup! haha
    Jun 05 2007
    Phillips Ranch, CA
    ^ Hey thats alright yours is an 06 mine is 07, I like to drive. LOL
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    I have to disagree with the rotors being worn down. Although I don't want to rule that out completely, I firmly believe you need to add break fluid and that is all for now. If the problem comes back quickly then I would have the rotors looked at and checked for specs on them or the check around the master cylinder to see if there's fluid around it because then it would simply be a leak.
    Jun 05 2007
    Phillips Ranch, CA
    ^ I too would agree with that because I have not had one issue since adding the brake fluid and its already been a few months.
