Results 1 to 2 of 2
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    K04 inlet question.
    So I got my K04 inlets and 2 couplers and clamps (VAST).
    1. How the hell do you get the couplers on! Are they that tight of a fit? I'm assuming they are to connect the long pipe to the shorter one.
    2. I didn't get instructions on the inlets and I figure it will be self explanatory when I get them on the car... but how do they go together?
    3. Do I need another coupler to connect to the Y-pipe? If not then I figure I have to get a hose clamp since the factory one is almost a 1 time use only.
    Gracias in advance!
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: K04 inlet question.
    use some oil on the coupler and it'll slide in a bit easier.
    l gotta-- l gotta get
    a form from a scientist.
