Results 1 to 10 of 10
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Exclamation ATP Manifold Stud Thread Size???
    Hi guys,
    Can anyone tell me the thread size for the studs that connect from the manifold to a GT28 turbo for the ATP manifold?
    I have a feeling that I was sent the wrong studs . I received 8mm x 1.25 studs but I think I need 10mm x 1.5.
    So do I need:
    * 8mm x 1.25
    OR
    * 10mm x 1.5
    OR
    * Something else?
    Also, I would assume the same size studs are used for the wastegate port on the same manifold right?
    This is the ATP manifold I am referring to:
    - Image borrowed from Rosati
    Feb 17 2005
    Sarasota, FL
    Re: ATP Manifold Stud Thread Size???
    For the 4 bolt flange T3 = 10mm, T25 = 8mm
    The wastegate port is 8mm on either
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by A4ringedONE8T View Post
    Ok awesome. I am running the T25 manifold so I do have the right bolts. Guess I just need to clean up the threads in there. it was really sloppy in there.
    Thank you, I thought I was going to have to hunt down other studs to put in there since I was planning to put everything together this weekend.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    If for some reason your manifold ended up having 10mm studs you can get them at a Napa Auto Parts real cheap instead of ordering them online from somewhere. It shouldnt though if it is T25 unless you bought it used and someone upgraded to larger studs.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by A4 TSCHUSS View Post
    I don't think that is the case...
    Although I might have to upgrade the hardware since one of the holes looks a marred up. I'm going to try to tap it with a 8mm first to clean up the threads then if that doesn't work I'll head over to NAPA (thanks for the tip btw, didn't even think of napa).
    Apr 24 2005
    E55 AMG, CTS-V
    Yeah they are real cheap, I bought some studs there once for like $1 a piece (7/16" size) little bigger than 10mm and some studs for the head were less than $1 a piece.
    ~David~
    CTS-V 9.6@148
    Apr 10 2007
    Eastern PA
    Got the studs into the manifold and decided to bolt up the turbo since it's easier to do now just in case I need to customize anything before this weekend when it is finding a new home under the hood of my car.
    I did however notice what looks like a casting screw up. It looks almost like there is a bubble under the flange where the turbo connects to the manifold. I tried to snap a shot of it but my camera blows. Is there anything I can do about that? Like fill it with something?
    Feb 27 2005
    North Wales, PA
    looks fine. That hole is from drilling and tapping holes. Its all good. See this weekend man.
    Apr 10 2007
    Eastern PA
    Ok, guess I'm just paranoid. C ya Saturday.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Looks A ok. See you this Saturday.
