Results 1 to 21 of 21
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Sb Stage 3 Clutch Wear In
    Shop told me to take it easy for 500 miles.
    Is that enough?
    Can I not boost? Or just avoid rough take offs, etc?
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Re: Sb Stage 3 Clutch Wear In
    500 is a common mark for clutch wear in. No launches, try to avoid quick shifts, stuff like that. I.E. once you have the clutch engaged you can floor it if you want.
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    500 miles is good. You can boost just try not to be in boost while shifting
    Mar 12 2008
    Portales, NM
    Thanks people!
    And man this clutch feels way different that my stock did :D
    Not rly hard [yet] but just smoother.
    Dec 25 2004
    Earth
    I thought you were selling your car?
    Mar 12 2008
    Portales, NM
    Quote Originally Posted by MikTip View Post
    http://tucson.craigslist.org/car/779175230.html
    Clutch went out shorty after.
    I guess I should delete that.
    How'd you find?
    Buncha motorcycles
    Memphis, TN
    you need at least 500 city miles of stop and go, stay out of boost! highway miles dont do much for breaking the clutch in.... i know its tempting but you do have one feramic disc which takes longer to break in.... go find the biggest traffic jam and just stop and go
    i had to wait 1000 miles! plus prior to that my clutch was slipping so i had to drive super easy and out of boost for over a month. so boring..
    APR Stage 2/AWE Intake
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by jbrown7815 View Post
    Is that enough?
    Stock flywheel or LWFW?
    Mar 12 2008
    Portales, NM
    SPEC 16lb Steel LWFW
    Jul 07 2004
    socal
    Ok so you have a OFE disk.
    Best way to break it in is by doing plenty of stop/go traffic driving or you can do very short WOT runs on the fwy at low rpm and low MPH in 5th gear. This will put high load on the clutch and allow you to have more time to react if the clutch does slip. You only need to do this for 2-3 seconds at a time. Doing normal fwy driving for 500-1000 miles isn't going to do anything since your not really using the clutch because it is already clamped down.
    Mar 12 2008
    Portales, NM
    So floor it in 5th while going pretty slow?
    Everything feels good on it and I've only put 50 miles on it. Must...wait...for.....500 miles....
    I wanna go on a "spirited" drive oh so badly XD
    edit:
    BTW sorry I didn't get it all thru you, the shop I was working with wanted to make some money I suppose...
    Jul 07 2004
    socal
    Yes you can do it that way. Thats exactly how I broke in my very first WOA clutch back in 2001, even did the break-in within 50 miles and then took it to the drag strip.
    They most likely didn't make all that much on the clutch so its cool, it isn't like there is a big wholesale discount on SB clutch kits. What you did end up with is just a standard SB kit though.
    Mar 12 2008
    Portales, NM
    Yeah I know. Had I not already had check out to them [couldn't change] I would have gone with you.
    Jul 11 2008
    Illinois
    So no WOT in first or second and so on?
    Anthony
    Mar 12 2008
    Portales, NM
    Quote Originally Posted by GTRS A4 View Post
    I have a little bit and no problems, but I try not to too much.
    Did you get SPEC 16lb FW also? I have Stage 3 SB + Spec FW.
    We have about the same setup
    I just can't wait to wear mine in more...
    Jul 11 2008
    Illinois
    I went Stage 4 and 9lbs. FW
    Anthony
    Mar 12 2008
    Portales, NM
    Oh wow, nice. I heard 9lbs would be WAYYY too light. Mine at 16lbs has some chatter. How is that? :eek:
    Jul 11 2008
    Illinois
    Haha! Not bad at all actually! Some vibrations upon engagement with the clutch but that's it. I wouldn't have done it any other way!
    Anthony
    May 21 2007
    Florida
    so just one question...how exactly do you know its broken in? like how did you know it was broken in after 50 miles? im putting in my stage 4 ofe ss wednesday but dont know anything about breaking it in. im planning on doing the 5th gear thing btw.
    2018 Navarro Blue Q5
    Jul 07 2004
    socal
    Quote Originally Posted by doublezero30 View Post
    It will slip at first during break-in, you will know it is broken in when it no longer slips under high load.
    Mar 12 2008
    Portales, NM
    I mean I've only taken mine 50 or so miles, and I haven't felt any slipping at all. I'm kinda scared to get on it too much, though. Can not afford another clutch/install :P
