Results 1 to 25 of 25
    Senior Member Two Rings montess2001's Avatar
    Jan 20 2008
    Westchester, NY
    Coilovers Squeak WTF?!
    Ever since I had my stasis c/o installed, the rear springs squeak like mad! I went and applied some lubricant that came w. the kit on the rear spring and perch and the noise went away (for about a week).
    My ? is:
    1. Has anyone else had this annoying problem?
    2. How can I fix it for good?
    Current: 2015 SQ5 / 2016 ATS-V 6MT
    Mods: 034 Stg I + TCU / H&R+B8 / Neuspeed Rse103 20x9.5 et 25 / Carlinkit
    Previous: 8V S3 Daytona launch ed. / E92 M3 6MT / E39 M5 / B7 A4 Ibis 6MT Ti big turbo.
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    Re: Coilovers Squeak WTF?!
    i too am hearing that. also interested if there is a solution.
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    Senior Member Two Rings g_svan's Avatar
    Jul 25 2007
    -01 RS4, -85 90qt(981whp), -19 RAM 1500
    Sweden
    I read something about this... I think the solution was to have full load on the springs before you tighten the bolts.
    Good luck!
    /g_svan
    Senior Member Two Rings rbecker's Avatar
    Nov 30 2006
    Los Angeles, CA
    mine squeak like crazy too, not ss but vogtlands. it's primarily coming from the front passenget side. i'm taking it into the shop on friday to investigate.
    there are other threads on here discussing this topic, some have mentioned over torqued bushings...
    06 Quartz Grey Avant 2.0T Quattro
    Fomula One Tint
    Vogtland Coilovers
    19' J Line 10RL2 Wheels
    245/35 Kumho Ecsta SPT Tires
    VAG Com goodies...
    Nov 12 2007
    Grand Junction, CO
    I'm pretty sure it's normal.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by AudiWxGuy View Post
    Normal would mean that the design permits it to squeak.... I'm pretty sure it's not entirely bad... but definitely not normal
    Aug 08 2008
    2017 Q5
    Houston, TX
    its normal for the squeaking? I think that should not happen. esp if you pay over a grand for a set of c/o's.
    is it something a lot of people are experiencing? I am interested in the stasis c/o set and would like to hear other people that have the set if they have any problems.
    Jul 20 2008
    Chicago
    If you removed your sway bar(s) while installing the coilovers, check the sway bar bushings. Sometimes, when disturbed, sway bar bushings develop a squeak or squawk that sounds like it would be from the springs. If it's the sway bar bushings, you can try to R&R with some good silicone grease or replace the bushing altogether. If it's where your springs are mounted that is the cause of the squeak, best to check that all fittings are torqued properly.
    Nov 12 2007
    Grand Junction, CO
    Quote Originally Posted by Sanjman View Post
    The shop I get my work done says its very common on a wide variety of coil overs. Plus, the fact that many people who responded to this thread with squeaking goes to prove my point. It's normal.
    Jun 05 2007
    Phillips Ranch, CA
    Wow, I've really never that this problem at all with my S/S coilovers
    Nov 12 2007
    Grand Junction, CO
    mine squeak a little...but it's not very noticeable. When I go in for my 25k service I"ll have my Audi dealer, who is a STaSIS dealer, take a look just to make sure everything is A okay.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    no issues with my bilsteins ;)
    Veteran Member Three Rings cyanidecologne's Avatar
    Oct 26 2006
    2006 BMW X5 4.4i Sport Package, 2006 Audi A4 2.0T Quattro
    Tustin Ranch, Ca
    Im squeaking too my friends on my teins
    Veteran Member Three Rings jayuuey's Avatar
    Aug 22 2007
    SF Bay Area
    im squeaking a little bit with konis but its not very noticable. i thought stasis c/o would be quiet since it comes with the special perch bushings.
    Jay
    Current: Ibis White A4 Avant S-line TI 2.0T MT6 (JHM STS, Unitronic Stage1)
    Sold and quickly forgotten: 09 Forester XT Limited
    Sold and will be missed: A4 2.0T Quattro, 6-speed manual, APR Stage 2+
    (old) norcal audizine GTGs, etc. http://www.flickr.com/photos/jayuuey/sets/
    Nov 16 2006
    Skokie, IL
    Not trying to argue with you... but clarifying that the people who have coilovers squeaking may tend to more likely post on this thread than someone who has coilovers that don't squeak. So you can't really take this a proof that it's normal. Just saying .
    anyways i'm dying to get some C/O's... but i'm spending all my money on booze, bitches, and car payments... and I can't stop spending.
    Jan 20 2008
    Westchester, NY
    Come on guys- there's gotta be a solution!
    Nov 12 2007
    Grand Junction, CO
    I actually took some speed bumps tonight and I didn't hear any squeaking at all. Its been a lot less noticeable since I've been raised a bit. Maybe you're too low?
    Jan 20 2008
    Westchester, NY
    Sitting at standard preset height (25.5"-26" all around)
    Veteran Member Four Rings Mr.Audi's Avatar
    Feb 26 2008
    none
    BALTIMORE
    iam going to silicone spray all the bushings and moving parts in the suspension right before setting the ride height... but iam going to attempt to go lower then the preset heights
    B8.5 S-line prestige
    #fourringarmy
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    No squeaks here with 9K miles on Stasis SS installed by moi
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I have the Stasis SS on my b6 with no squeaks at all, did you guys do DIY or shop install?
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Quote Originally Posted by montess2001 View Post
    My ? is:
    Never had any issues with ALL of the STaSIS coilovers we've installed.
    Do you have the white spring perch spacers under the springs?
    It sounds like you had a shop install them? Has the shop looked at the issue?
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    I posted this in another thread...
    Everytime I read something pretaining to Stasis coils... this pops into my head... you cannot install these with an impact gun.. from what I gather these are one of the few if only coilovers that shouldn't be installed with one... and it seems 75% do or try to.
    Stasis should write that in huge red letters on the box... as most people assume they are just like every other suspension setup and use an impact gun. correct me if im wrong...
    789whp
    DUH! an Audi
    los angeles, CA
    solution to squeak is simple: loud music...my solution to all the cars noise problems
    seriously, wd40?
    May 27 2004
    Portland, OR
    Quote Originally Posted by Howard Hughes View Post
    There is a specific installation method yes....really same way with other coilovers (load the susp and tighten the fasteners).
    Jeremy Williams
