Results 1 to 40 of 54
    Dec 03 2005
    2 pedals 1FG
    connecticut
    some more fabrication (boost gauge in rear-view mirror)
    Here's the original thread where I got the idea: http://www.audizine.com/forum/showthread.php?t=93113
    It seems to fit the theme of my Avant very well: "non-flashy" or "stealth". I want my interior and exterior of the vehicle to look 'stock'. Albeit the exterior is Stock B6 S4 but its still stock.
    So, I decided back in May to give this a try. Why not? What is to lose? Oh yeah, destroying a $500 mirror (due to the auto-dimming and compass feature).
    With all the projects I've added to the Avant this little mod has sat on my kitchen table for the entire summer. It has sat staring me in the face and I've ignored it due to procrastination.. Procrastination because I'm worried I'd fcvk something up and be out a $500 mirror.
    Anyway. I had the mirror apart back in May when I figured out how it comes off the car (rotate entire mirror assembly 90deg and it comes off the tab that is glued to the windshield).
    I then managed to break just about every little clip that holds the trim ring on when I was separating the mirror halves. Those are difficult little buggers. There has got to be some special tool because a screwdriver doesn't work. Later found out you can't buy the trim ring by itself. Yummy
    Bottom left corner is the most amount of space for said boost gauge.
    One needs to cut out some plastic so I opted for my trusty dremel tool. Big mistake if your blood sugar is low and you have the 'shakes'. Little too much pressure with the cut-off wheel and next thing I know I've got a nice nick in the mirror itself. (very small, can only see it if you're within 4inches of the mirror). Immediately stopped using that tool.
    Figured out how to break the casing on the boost gauge because I need the breadboard and the amber acrylic surrounding it.
    Marked where its going and started scraping the coating off the back of the mirror. I started with a small wood chisel because it was the perfect width. That was getting no where so I opted for the dremel. Didn't I just learn my lesson? Nope. Next thing I know my dremel has gouged the glass itself. I'm fcvked. Mirror is toast now from an aesthetics standpoint.
    (see scratch in center from dremel and the small nick above from the dremel cut-off wheel)
    Why? I was told to use x-acto blades but that would take forever. I opted for quicker path and shot myself in the foot as a result of an attempt at speed. Some quick thinking and I realized that huge scratch is right where the decimel point will be. Not a big deal. You won't see it if you're driving or a passenger. You'll see it if the car is stationary and you're being the white-glove guy picking out every little detail wrong with the car.
    Let the effer sit for a few months because I'm pissed and am contemplating what to do. Found a Saturday evening where everyone was out of town and I didn't have any dates so I decided to sit down at the kitchen table with about 10 x-acto blades and start scraping. Outlined and then little by little I scrapped the auto-dimming and mirror coating off the glass.
    What do I glue it with? I opted for some plastic epoxy (stuff I used on my fog light). That turned out to be yet another mistake. The epoxy is strong stuff, stronger than required for this application. I used a conservative amount yet still had too much. It smeared all into the opening I made. I then realized that it was also eating away the amber acrylic the gage was within. Fcvk! Another set-back. I broke the acrylic apart and got the gauge out. Cleaned up the mirror and then went looking for a suitable amber acrylic. Found that and found this cool glue called "Weld Bond". This stuff is awesome and is the glue I'm using on this project (and it works!).
    The gauge itself has red LEDs but if the gauge is outside the acrylic box the LEDs are visible. I didn't want them visible if the car is turned off so I bought some acrylic and went to work cutting and shaping a new 'box' to put the gauge inside.
    (ignore the glue on the gage, you won't see that when finished. That was one of my trials that went south.)
    Took me two attempts at getting one that fits the gauge perfectly (cutting 5 pieces: 4 sides and 1 faceplate) as you can see in the image just above.
    Now on to gluing the gauge onto the mirror. Haha. Took me 6 tries to get it set so the glue wouldn't seep through. This is where I like the Weld Bond. It goes down like Elmer's (white) and dries clear. Gets tacky in a few minutes and bonds within an hour or two. Best to let it sit for 24hours for permanent bondage [beavis & butthead] huh, huh, huh. yeah. yeah! [/beavis and butthead]. If you don't like how the glue sat. Immediately pull it apart, wipe it down with a paper towel. Then wipe it down with a separate paper towel that has some Windex on it. Good as new again for the next attempt.
    Had to resolder the wires because they were getting flimsy from me man-handling this thing. Once again, the blood sugar was low last night and I grabbed the wrong end of the soldering iron. Went to bed with two fingers doused in Aloe and bandaged up as if I had them cut off on a lawn mower.
    (the amber acrylic makes this look nice when the car is turned off)
    9volt battery hooked up to give you an idea of what it looks like when turned on:
    Yes, it reads vacuum!
    As you can see, this is an 'extreme close-up' and you can barely make out the huge gouge I put in the glass. In the car you won't see it. You'll be distracted by the numbers instead. Mission accomplished!
    Next thing to do is to let this sit and dry for another day. Then reassemble (had to trim a little off the inside of the mirror casing back) and glue the trim ring in place with some Weld Bond. Then put back in the car, run the wire up along the headliner and down the a-piller to the wires I have in the dash coming in from the engine compartment.
    It looks good. Could it be better? I think so. I know the flaws in this mod and it irks me so I won't be happy unless its 100% clean.
    Would I do it again? Right now. NO. In a few months. Perhaps.
    -Doug
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Re: some more fabrication (boost gauge in rear-view mirror)
    NICE!!!! That looks sweet! Good work!
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Good job, looks almost as good as mine (You have a better pic of your though)
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    wow, thats a good idea and really good execution!
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Jun 08 2008
    Calgary AB Canada
    awesome!
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    nice write-up. great job guys.
    i prefer my awe vent boost gauge .
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    looks good, i like this over any pillar or vent mounted gauge, keeps the car looking real clean.
    BTW what brand gauge did you use?
    Please Drive Right
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by RLB6 View Post
    Thanks. At least your glass isn't scratched. haha. I'm so happy that I've finally gotten over the hump of gluing it onto the mirror. Its been a big pain in my ass. That's why its September and I'm still finishing it. I've driven over 5,000miles with the new motor and no rear-view mirror (had the gauge tapped onto the dash for a while).
    -Doug
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    very nice, very clean. Would is work in a b5 mirror? lol
    Senior Member Two Rings Adam 1.8's Avatar
    Jul 07 2007
    Audi S4
    Ottawa, Canada
    holy shit that's awesome!
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    looks good.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Registered Member Two Rings bigbro's Avatar
    Jul 27 2008
    Black 05 b6 a4 1.8T Quattro AT
    I still think this is the best boost gauge mod for the a4. Good work
    05 Triple Black 1.8T Quattro Tip.
    Veteran Member Four Rings FITZ TITS's Avatar
    Phila
    Modded disposable digi-cam too?
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    I love it ..good job
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Its operational!
    I pulled the sunroof controls out, driver sunvisor and the driver a-piller. Then ran the wire down the a-piller behind the drain for the sunroof (away from the airbag). Hooked everything up under the dash and reassembled the dash. Good as new again!
    -Doug
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    Amazing work. Good job!
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I just might have to do this....too cool to pass up
    Are you using this in conjuction with an analog boost gauge?
    -Sami-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    No. the whole point of this was to have a boost gauge that does not clutter up my interior and give notice that there is something under the hood when you stare at the parked car.
    -Doug
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Very impressive install...and very courageous to tear apart such an expensive piece of the car. You should consider marketing your services...
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    I likkee this ALOT!! Too bad I have a 3.0l ! Just out of curiosity, if I were drunk one night, and got the insane idea into doing this mod to my mirror, what "gauges" could I run?? Since I dont have boost, I cant do a boost gauge... what all is there? lol
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Active Member Four Rings
    Dec 11 2006
    Boston
    Douglas, you are the master of gauge relocation.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Frey7190 View Post
    You can be creative as you want.
    This is the gauge: http://www.dynotunenitrous.com/store...?idproduct=131
    They also make (in this size)
    - Innovative Wide-Band A/F gauge
    - Fuel Pressure
    - Nitrous Pressure
    - Battery Voltage
    - EGT
    Oh, and here are a couple other thoughts:
    - Valentine one display
    - shift light
    etc...
    I am actually entertaining the thought of making a digital strip out of a few gauges. This will reside either right at the windshield and dashboard intersection or fill in the region where your cup holder and change drawer resides.
    Quote Originally Posted by Arclight View Post
    I had a good friend interested in me doing this for them but I turned 'em down. I am too meticulous and, as a result, see all the flaws with my mirror. I don't want to have to re-do things many times over again (like I did here) and be responsible for someone else's vehicle. Not at this point in time. I've got too much on my plate right now.
    Quote Originally Posted by deb38 View Post
    Thanks, Rookie Biatch.
    -Doug
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    You have put 5,000 miles on your car in nine weeks!!! jesus
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by lookaught View Post
    Yup. I built the car to drive it
    -Doug
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Now thats f-ing kool Good job
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Oct 29 2005
    10speed
    San Francisco, CA
    hey doug hows that trans? I wanna get a ride in the car when its tuned so bad
    - Clint
    Registered Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    Quote Originally Posted by Adam 1.8 View Post
    times a 1000x
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Trans is holding up perfectly fine. Once I clean up my basement, this winter, I want to take apart my 1.8 trans and find out why 3rd gear was grinding. I think its the syncros. Then probably find myself a 5th gear out of a TDI and rebuild the 1.8 trans and put it back in my car. I kind of miss the shorter gears in 1-4 but at the same time kind of like cruising around town in just 2nd gear .
    So do I. So do I.
    One doesn't realize how much more the car drives/feels/behaves with a solid tune. I've been looking forward to tomorrow for three months. I might not be able to get to sleep tonight I'm so excited. I'll call you later tonight. I might just need a ride from Somerville up to B-water. Looking at train or bus schedules from Cherry Hill up to Somerville.
    -Doug
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    Nothing like the dremel jitters to make things more difficult! That tool can definately be nerve racking. Gj on the install. +1
    -Matt
    FCDT Member #1
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    i love this project! i'm going to undertake the task once i have money for that gauge. do you have any pics or advice on how to remove the headliner and a-pillar? that's the part i don't understand yet....
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings HoRnYTuRbO's Avatar
    Feb 24 2005
    10 RX350 || 04 B6 1.8T
    Brookline, MA
    nice and clean
    Feb 19 2007
    Charleston, SC
    How does the gauge get the reading/signal for boost?
    -Sami-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by LampyB View Post
    Pop open the cover that houses the sunroof controls. Two philips screws up front hold the controls in place. Take them out and disconnect the wires.
    Pop off the cover (carefully with a flat screwdriver) for the stationary clip that holds the sunviser forward. It pulls straight down and out. Then pull the rest of it off.
    Pop off the tiny circular cover on the sunviser pivot point to reveal a philips screw (or is it torx? i can not remember). Unscrew that. Rotate the sunvisor horizontal across the car (normal position). Gently pull down and rotate towards the rear of the car. The sunvisor will then pull out of a hole in the chassis. Disconnect wires.
    Pop off the 'airbag' label near the b-pillar above the driver headrest. Unscrew the torx screw behind it that connects the a-pillar to the b-pillar.
    Pop off the two covers for the 'o-shit' handle. Unscrew the two torx screws.
    Gently pull the a-pillar towards the inside of the car. There are three to four clips that hold it into the a-pillar. They will come out and the a-pillar cover will come off.
    The headliner is loose now so you can sneak your fingers under it from the windshield to run the wire. Run the wire down the a-piller behind the sunroof drain. Make sure not to put it infront of the air-bag otherwise the air-bag will not deploy correctly.
    Unbolt the lower half of the dash to run the rest of the wires (see a4mods.com for directions).
    I connected the power to the switchable power on the steering column as noted in the a4mods.com turbotimer write-up. I found ground at the fuse box also like a4mods.com. I ran the wires through the ECU box from the sending unit.
    Like any other gage:
    I mounted the sending unit on the frame rail under the radiator coolant reservoir (out of sight). I then put a 't' fitting in the front vacuum port of the intake manifold and ran a line to the sending unit on the frame rail. Just like the a4mods.com boost gauge write-up.
    Pretty simple.
    I'll get some photos tomorrow of the sending unit and its location/connections.
    -Doug
    Feb 19 2007
    Charleston, SC
    Thanks Doug. What I was concerned about was the sending unit, so that sounds great....how big is it?
    Now, i am just debating if I want to go with the coventional gauge or this mirror one....maybe both?
    -Sami-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    The sending unit is slightly larger in diameter than a fine point Sharpie pen. Say, 3/8" in diameter? Again, I'll post up a picture tomorrow. Its wet and dark out and I gotta shower and get on the road so I can get my car down to ASP tomorrow morning.
    -Doug
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    yup, dougs the man...
    Feb 19 2007
    Charleston, SC
    I bet your excited
    -Sami-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I have gotten quite a by of interest in this mod. This has driven me to think critically on how to improve the process of adding a boost gage (or any gage you desire) to the rear view mirror.
    I am willing to do this mod for people. Please PM me if interested.
    Thanks
    Doug
    -Doug
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    is that LCD bright enough to shine through some of that "mirror" tint? maybe put a small piece of mirror tint on b4 u install the display to sorta hide the black cutout
    -06 A4 2.0T
    -97 A4 1.8T
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    all i gots to say is wow that is way cool, been looking for a boost gauge solution for a bit and i just found it :)
