Results 1 to 10 of 10
    Oct 22 2006
    Second timing belt job approaching need some more audi advice
    Hey im 4000km away from needing my second timing belt @ 200000km for my 2000 A4 1.8t TIP and i just had a few questions regarding it:
    1. Do i need or should i replace pulleys with OE
    2. Who has the best kit right now
    3. can my engine handle k04 after this second timing change
    4. Is there a 200km service
    5. Can i do this my self having no major mechanic knowledge
    im also getting these things done aswell:
    Combi vavle
    stock cat to HFC
    trying to solve evap problem
    but is there anything else i should change while im getting this done, thnx
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Second timing belt job approaching need some more audi advice
    Quote Originally Posted by karmad View Post
    - which pulleys? why fix it if it ain't broke
    - www.mjmautohaus.com and www.ecstuning.com
    - if your engine is healthy then why not (it's weak sauce and need other mods to make it work right)
    - timing belt and whatever is broken i guess
    - if you know how to use tools and know how to search this website then you can try
    Combi vavle easy, back of the head
    stock cat to HFC pain the *** job
    trying to solve evap problem good luck
    snub mount, gaskets if you have oil leaks, gloves, shirt
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    While you're in there I would replace the pulleys. Water pump and T-Stat isn't a bad idea either. It's a lot cheaper to spend the cash once, than have to do it again. Even more expensive if one of the components causes the belt to break.
    Doing the job is pretty straight forward, but if you don't think you can do it, just ante up the bills. Where are you in Canada? I'm sure there's somebody along the border that could help you out.
    As long as your compression is still fine, the car should be able the K04 without any issues. Obviously the correct MAF, injectors, and tuning should be in place as well.
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    did my timing belt at 148 km and then went K04 @ 160. You're 99% fine. Just make sure there's no sludge, and you should be fine. I totally agree with everyone else here. Timing Belt, Tensioner, Water Pump (or entire water pump), you can do the pulleys, but that's a judgement call. I'd do the snub mount if I knew I was going to be upgrading the other mounts soon. I've heard bad things about upgrading the snub without doing the engine/tranny/diff mounts. It's an easy job. Out of caution, get a 12pt socket....forget what size, just in case you need to move the crankshaft. If you're in the GTA, I could probably give you a hand, but it depends when. My first one took about 8 hrs.
    Oh....you need G12 coolant and distilled water too!
    05 allroad 2.7T Stock
    99.5 A4 1.8T K04 - Sold
    Apr 01 2007
    Irvine
    My first time took about 8 hours, but now i'm fairly confident I can go from parked to completely done/tools cleaned up in just a tad under 3 hours.
    Couple hints...
    go with a good, OEM water pump. I got some cheapo replacement at pep boys and it wouldn't fit properly, even after grinding down some parts to get it to fit.
    Easiest way to deal with the belt is to make 2 marks using white out or somethign similar on the old belt; make the mark starting at the edge of the belt's side and then all the way onto the sprocket (both the upper camshaft one as well as the crank sprocket). Then, just make the same marks the same number of teeth apart on your new belt and match them up with the marks on the sprockets.
    Before turning the car on, turn the crank 3-4 times over by hand to make sure everything's in properly and no valve-piston contact will be occuring.
    watch the tension on the AC condensor when you put it back. The first time I didn't tension it down hard enough, and when the AC was on I got a serious vibration through the entire cabin.
    the right tools make a huge difference. I wouldn't try to remove the bolts holding on the crankshaft accessory pulley with anything other than a hex key socket set - anything else runs the risk of stripping them out.
    You'll need a universal joint neck to remove one of the bolts holding on the timing belt cover.
    make sure everything is plugged back in (horns, AC unit, etc) before putting the bumper back on - some stuff is a bitch to reach once it's on.
    Other than that, it's a real simple and straightforward job. Just take your time and don't rush anything.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by hoganalley View Post
    What? What problems, I have density mounts all around for lots of miles w/o any issues.
    Established Member Two Rings A4Gasm's Avatar
    Jan 24 2008
    98 Audi A4, 06 Suzuki GSXR600
    Boston Massachusetts
    I got the kit of ECS tuning which provides everything you could possibly need. Came with a new water pump, coolant ETC. Was approx $260. DIY saves you HUNDREDS!
    The guy I have doing it is really experienced, he's done one on a civic and a VR6 jetta, regardless, I wanna bring some info with me. Are there any detailed DIY write ups for TB changes on here?
    98 A4 1.8TQtip
    Gpop K04 Hybrid / GIAC pump /3.0" magnaflow at the downpipe / Baily DV / AWE Vent Boost Gauge / 17" Gloss Black S4 AVUS / K&N in stock box / Smoked Side Markers / Debadged / 20% Tint / Kamie Grill / Facelift Tails with Foglight Mod / Blitz Dual Turbo Timer
    Buy my cd player and subs please http://www.audizine.com/classifieds/...ct=2353&cat=44
    Jan 21 2006
    6MT BT Avant Ti
    RI
    ^ A civic takes an hour to do and a VR6 does not have a timing belt so watch this guy (does not sound like much experience). There are write ups here and on AudiWorld tech articles.
    Established Member Two Rings DuviVr6's Avatar
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    Quote Originally Posted by nebone22 View Post
    VR6 do have a timing chain and its no easy job to change em!
    Veteran Member Four Rings SFexBOY's Avatar
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    I did my 2nd TB a yr and a half ago, and just did the normal replacements.....wp, all related belts, vacuum lines.....and snub mount (since my first APR one was annihilated). I'm quickly approaching my 3rd timing belt replacement, come to think of it.
    '90 BMW 325i...SOLD!
    '89 BMW 325ix...SOLD!
    '05 BMW M3
    01.5 A4 1.8TQ (175K, owner since 4K)
    My cars.
