    Forum Moderator Four Rings doobiesdaddy's Avatar
    Sep 05 2008
    2001 Stage 3 allroad 2.7t 6mt TDI gearbox , 2021 Mercedes E 350
    Montana / San Francisco
    402 mod and alignment
    If I have done the 402 mod and dropped my allroad, do I have to return it to factory spec on the height adjustment when I get new tires and do the alignment?
    Dave - Moderator
    Issue? send me an email
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down ‘happy’. They told me I didn’t understand the assignment, and I told them they didn’t understand life.
    -John Lennon
    Veteran Member Three Rings scot_w's Avatar
    Apr 05 2006
    '04 allroad 4.2, '00 A4 1.8T QWSM
    Re: 402 mod and alignment
    Although the "default" is to align on level 2, the guy I use says you should have it aligned at the height you normally run for most of your driving.
    Sep 05 2008
    I know default alignment is on level 2. What I want to know is do I need to reverse the 402 mod (raise 20mm) to align when I get new tires, or should I align it with the car lowered 20mm on the 402 mod?
    Dave - Moderator
    -John Lennon
    Veteran Member Three Rings Kemer1's Avatar
    Aug 26 2008
    05 Audi A6 3.2 Quattro
    Sin City
    If you're going to be running it at it's 402 height, then allign it at that height. If you're going to be running it at level 2, then get it done at that level.
    Apr 05 2006
    Sorry I stuttered?
    Quote Originally Posted by scot_w View Post
    If you want to do anything with your 402 mod before you align, I would make sure each corner is the same.
