    Senior Member Three Rings lisn2me's Avatar
    Apr 03 2004
    2011 A4, 2014 S4
    Cleveland
    Brake Pad and rotor suggestions....
    Need to do my brakes. I am looking at the ecs 2 Piece OE Replica rotors and not sure on what pads. only have a bout $1000 to spend on them. So big brake kit is out of question. Any suggestions?
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    Re: Brake Pad and rotor suggestions....
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    I'm running the ECS light-weight 2 piece floating rotors. Saved 12lbs per side up front and 1lb per side in the rear (just for looks). You'll see people post about ECS rotors warping in the past, but I know several owners who got great mileage out of them. Sia got over 30k (then sold his car) and Eddieman has gotten over 40k miles so far with no problems. All rotors are subject to warping if abused. If you're just driving street, you'll be fine. As for brake pads, I'm running Carbotech. You can find them at several vendors online or directly from Carbotech. Ask for Mike Jr. and pick his brain for best application for you. Outstanding products and excellent customer service. They will provide you the perfect application for a direct OEM fit (shims/springs/clips etc). I've got the Bobcats on my S4 and they are very low dust with excellent bite. Did I mention low dust? Oh, you'll have to short your wear sensor wire (not needed anyways and you'll seriously limit you pad choices if you insist on keeping this feature not to mention added cost).
    Have a good one...Steve
    http://www.ctbrakes.com/
    Office Hours:
    8:00am-5:00pm
    Monday-Friday (eastern time zone)
    closed Saturday & Sunday
    Contact Info:
    Telephone numbers
    Toll Free: (877) 899-5024
    Local: (704) 481-8500
    Fax: (704) 481-8554
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    This is not too bad of a deal either.
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Word of caution - stay away from Hawk pads for the S4 (fronts). They make the correct pad, but they do not have the correct clips which in turn do not allow you to re-install your spring clips.
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
