Results 1 to 3 of 3
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    window regulator replacement question
    Do I actually need to get the window all the way down before taking the door apart? The DIY says to, but mine is so jammed up it won't go further than half way.
    http://audizine.com/forum/showthread...ndow+regulator
    TIA
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Jun 08 2008
    Calgary AB Canada
    Re: window regulator replacement question
    no.
    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    I didint replace mine I just fixed the green bracket and for that You only need to get it down far enough to allow your torx tool to remove the 2 bolts that hold the green bracket to the black one glued to the bottom of the window.
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
