Results 1 to 18 of 18
    Active Member Two Rings mdfast1's Avatar
    Feb 27 2008
    Sunnyvale, CA
    Where to find a Wheel Ramp (RS4 Sway Install)
    I am set to receive my RS4 rear anti sway bar today and i'm looking for a good set of wheel ramps to raise the car and keep the suspension loaded while I work on it.
    I was looking at this one
    Does anyone with a B7 stock suspension know if this will have any issues with clearance and getting up the ramp.
    Thanks.
    May 11 2008
    Naples,FL
    Re: Where to find a Wheel Ramp (RS4 Sway Install)
    if you talking about the blitz ramps, no they would rub the front bumper and would clear fine.
    2.0 T Quattro - 20% tint,hardwired 9500i,alpine 757 amp,alpine 12" type r sub,RS4 Sway,Giac X-chip, VMR 19 710's wrapped in Conti Extreme DW, H&R Coilovers .
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    For the sway bar install you can easily back the car on these...but if you are lowered they will not work that well on the front since the bumper hits.
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    Someone correct me if I'm wrong, but I thought it was important to the suspension loaded the same way it would be as when you're driving. As in having all four wheels the same level without any one or two taking more load than they would normally... Thereby making it so that you would need to have all four wheels on the ramps or they are useless. I might be blowing smoke though...
    DUH! an Audi
    los angeles, CA
    ya, I heard something about having the suspension loaded to make the removal/install a bit easier.
    OP: if you plan on lowering your car, I wouldnt recommend ramps as when you lower you will more than likely not be able to go up the ramps from the front bumper. I had a set of ramps and had to give them away...wouldnt want you to go through that, save a few bucks.
    Sadly, you cant return ramps from autozone haha
    -randy
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    being on a ramp shouldn't change the load. it is the same as having your car on a step driveway and the front on the road!
    The usual things!!
    Resistor Install
    Veteran Member Four Rings yoogene83's Avatar
    Apr 27 2004
    2017 Pacifica Limited / 2014 BMW M5
    Seoul
    When they say the suspension has to be loaded, it just means that whatever section of the car your working on has to be at the same level. So if you're doing your rear sway bar, you should have both your rear wheels on ramps, but your front wheels can remain on the ground. this goes vice versa if you're doing the front sway bars.
    As for ramps, you can pick up a set for around $40 at Wal-Mart and they'll get the job done. if you're lowered, however, forget it, you need some race/lowered car ramps to get your nose in the air.
    Mar 03 2008
    Washington
    Quote Originally Posted by yoogene83 View Post
    Thanks for the clarification on that!
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    I use the Blitz Rhino Ramps you have pictured on Amazon's site with my lowered Avant. I had no problems clearing the front bumper until I added Votex chin spoilers. Slipping in a small 1/4 or 3/8" strip of plywood solves that problem though. they can be had for ~$40 from places like AutoZone or possibly Wal-Mart
    Feb 27 2008
    Sunnyvale, CA
    Thanks guys, that's exactly what I needed to know. Hopefully I'll get the sway bar on by the end of the week. Just need the ramps now.
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    I would not waste my money on those just get a pair of 2x10's and some cinder blocks.
    -Ian
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    i have the blitz ramps and even on my coilovers all i need is a small piece of 2x6 and i'm set for the fronts. rear you'll have no issues
    Apr 04 2008
    2006 Audi A4 Quattro
    South East Connecticut
    Quote Originally Posted by Vorsprung View Post
    I did this for my install, backed up a 2x10 onto a 4x4, gave me plenty of room underneath for the job. Not sure if the front end would rub on a lowered car, I've got 4x4 suspension still but my neighbor does the same thing with his EVO and that's lower than I am.
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    i usually just lift the car and use a jack to load the suspension.. either that or the rhino ramps are good, but if you lower the car, it won't clear..
    2008 Phantom Black TQM
    Apr 14 2008
    Milton VT
    rears clear fine with ramps...fronts need an aid
    Feb 27 2008
    Sunnyvale, CA
    Sears Automotive does not have any and neither did Walmart. Any other brick and mortar stores carry them?
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by mdfast1 View Post
    Autozone, Kragen, Checkers, Pep Boys... not sure what you have in your area.
    Awaiting Confirmation Four Rings
    Feb 29 2008
    2006 A4 2.0T Quattro, Dolphin
    San Francisco Bay Area
    Thanks.
    LOL, the stock B7 off-road suspension having clearance issues?!
    Sorry, someone had to say it.
