Results 1 to 3 of 3
Thread: CEL code help?
    Veteran Member Four Rings FLACO X3's Avatar
    Jun 05 2008
    B5S4, B7A4
    Thornton & Elbert County, CO
    CEL code help?
    Sold CEL reads: "Over Advanced Camshaft Timing"
    My valves are also ticking really loud under load and during warm-up of car, otherwhise the car runs fine. I am getting the cam timing chain replaced real soon, anything else that could set this light off?
    2000 S4
    2008 A4 2.0TQ
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: CEL code help?
    has the car recently had a timing belt service? if so you may be 1-2 teeth off. much more than that = catastrophic engine failure. Also, sludge is notorious for the 1.8t's and if you have bearing damage, audi will install a brand spankin' new engine (up to 8 years and unlimited mileage warranty) free of charge. if you can revert to stock fairly easily, take it to a local dealer and have them check it out.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Apr 27 2008
    White Plains, NY
    Re: CEL code help?
    Quote Originally Posted by FLACO X3 View Post
    What does Measuring Block 90 say?
