Results 1 to 6 of 6
Thread: blown dv's?
    Active Member One Ring DSIguy's Avatar
    Apr 23 2008
    blown dv's?
    A prototype system we made for 2 clients.
    And any Stage 1,2 owner blowing dv's,Ko4's and those wanting a responsive, mechanical solution to the factory valve and it's somewhat undesireable charecteristics. Sorry about the pics.
    [/IMG]
    [/IMG]
    [/IMG]
    DUH! an Audi
    los angeles, CA
    Re: blown dv's?
    ummm, I am lost =\
    what you trying to show?
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: blown dv's?
    Buy Apr Forge Dv!!!!!!!!!!!!!!!!!!!
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: blown dv's?
    well a new DV but need more detail and better pics. i think i'm feeling sick!
    The usual things!!
    Resistor Install
    Apr 23 2008
    Re: blown dv's?
    A mechanical dv, 3" inlet pipe, and upper charge pipe. all t304 stainless, tig welded. Eliminates blown valves, improves throttle feel, and upgrades the turbo inlet pipe and upper intercooler pipe. No fault codes.
    Just a prototype, next one will have a bracketed stainless crossover pipe. As well as a different valve. Could do a cone filter set up too, for the noise lovers..
    Apr 23 2008
    Re: blown dv's?
    Another one. This time with a Forge motorsport "supersize" dv and cone filter. The heatshield will be finished on next visit.
    This system solves several issues with the stock dv as well as stock placement aftermarket dv's(forge etc.), and behaves as a "cold air" recirculation system. Others are selling only a 3" mandrel bent pipe as an inlet pipe, no fab, no testing for over $150!!
    It's never what you do....but how its done.
