Results 1 to 14 of 14
    Veteran Member Three Rings ZachPDX's Avatar
    Jun 09 2008
    PDX
    Headlight adjustment... pt2
    So sunset audi replaced both my headlights this afternoon, everything looked fine. Then i began my 12 hour road trip and quickly discovered my lights are trying to light the sky. I pulled next to a wall and the regular lights shine just as high as the "high beams". I adjusted the screw that is parallel to the ground above the headlight to all the way in, it pushes the lights down a bit but not enough to make a difference. HELP!!! I HAVE to leave but ill check this thread on my iphone and i have some basic tools with me.
    Any help would be great!
    05
    JHM SM/LW Flywheel + Stg3 clutch | JHM Piggy's | Milltek nonres | JHM Tune | JHM 4:1 Center Diff | Neuspeed 25mm Rear Sway | APR snub | Apikol Rear Diff | JHM SSTS | Vogtland GT's
    SomeGuyInAChair - "I'll be honest about why I signed up for a car forum without thorough knowledge of cars. I merely did a Google search with the following key words: "milf cougar forum advice help tips"
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Re: Headlight adjustment... pt2
    if its a temp fix...get some longer screws
    Dec 05 2006
    So. Cal.
    We have auto leveling headlights. Adjusting the screw won't do it. You have to have Audi do the adjustment and they charge $125 to do it. Is your car lowered?
    Mar 09 2005
    Santa Clara, CA
    not the top screw, the parallel ones. he's getting new ones for some warranty work or something, he needs s temp fix
    Aug 11 2008
    Calgary
    I haven't really looked at how the light housing and the autoleveling works on the Audi but on my E46 M3, it does it's autoleveling according to the front control arms. You can also adjust the height by moving the whole headlight housing, I had one that was off when they put the angle eyes in my car.
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    No temp fix. Like I posted in your previouse thread, this has to be accomplished at the stealership. I can't believe they did that to you. Pretty poor service not to mention unsafe.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by S4J View Post
    Agree!
    Senior Member Two Rings mystro's Avatar
    Apr 29 2005
    Woolrich Pa.
    Headlight adjustments are free at the dealer. My dealer tried to charge me until I called Audi NA. Audi states all headlight adjustments are a saftey issue and are covered under the factory warranty.
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    you have to get it vagged to adapt the changes
    Registered Member One Ring sayporsha's Avatar
    May 07 2008
    Salem, OR
    Quote Originally Posted by ZachPDX View Post
    I had the same experience with Sunset. My headlights aren't pointing as high as yours by the sound of it, but my wife followed me home in the S4 the other night and it pert near seared my retinas.
    Jeff
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Quote Originally Posted by mystro View Post
    Anyone else verify this? I am having a similar issue. It seems like i am lighting up the headliners of the cars in front of me, more so than the road itself.. When i called my local dealer, they said that because my car is out of warranty i would have to pay for the repair/adjustment.
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    I aimed mine myself.... on the back of the housing there are two white plastic caps you remove (This is a B6, no clue if it applies to a B7) and then you use a torx bit and you can adjust the horizontal and vertical aim of each one. A total beatch to get it right unless you have somewhere perfectly level to do the adjustment though.
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by b spot View Post
    but if you have auto leveling, you need to use a vag to reset thebaseline
    Feb 03 2008
    canada
    I have a good one for you guys. I have a B6 but put s4 hids in after. Now i'm having to figure out how to aim my headlights. the leveling motors are there the the car came with halogens, so I don't think that function would work. is there anything else I can do?
