Results 1 to 32 of 32
    Established Member Two Rings stephengraham's Avatar
    Aug 27 2008
    Fredericksburg, Virginia
    Xenon Interior Pics
    Just finished putting in the xenon 18pc kit.
    Had two bulbs left over and realized it included license plate bulbs.
    My mistake, the two bulbs I thought were for the plate were for the vanity lights that come on with the visor. They are the same size though.
    One small fitment issue with the dome light bulbs, the kit came with 4 of the bullet style bulbs, all the same size. The ones in the dome light are longer than what the kit came with, I bent the contact tab in just a bit and put the bulb in at a slight angle, it fit ok and makes solid contact. They are the correct size for the license plate though.
    In short, it looks amazing. The xenon lights the aluminum trim up beautifully. Only thing I could pick at is that it doesn't light up the floorboards as well as the original bulbs, but its good enough and I wouldn't call it a complaint by any means.
    Installation tips:
    - The two panels for the front and rear reading lights pops entirely out, don't try to pry out the small lenses. Also, the main dome light is easier to pop out with the reading light panel out. I started with the dome light and then moved on to the front reading lights and realized it would have been easier getting the dome panel out doing it the other way around.
    - The light fixtures for the 4 floorboard, 4 doors, and the glove box are all the same, some were easy to pop out and others hard. They pry out from one side and then slide out down and toward the popped out side.
    - I did this at night because I'm impatient and just got my car back from the shop. I would recommend doing it during the day, leave your doors open until the lights time out, it gets annoying trying to pull hot bulbs. Instant gratification though, doing it at night.
    I shot these all with the same white balance setting, it looks pretty much like the real deal color wise in the photos. Pardon the blur.
    Before
    During
    After
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    Re: Xenon Interior Pics
    much improvement! Your photos are sick how you put the before and after pics in each other.
    Veteran Member Three Rings seadoo4563's Avatar
    Aug 10 2007
    Annapolis,MD
    definitely bright
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Not bad at all.
    I'm curious to know what's the name of the kit and where'd you get it.
    Also, are the bulbs the same wattage or higher? I'm always worried about putting in bulbs that are higher than OEM wattage because it'll melt whatever housings they are put in or it'll fry the wiring.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Registered Member Two Rings
    Nov 05 2007
    Overland Park
    Yeah where did you get these?!?
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by kyle09 View Post
    Did a quick google search and found this...
    http://www.xenonfactory.com/products...light/audi.htm
    Don't know if this is the one though.
    -Anil
    Aug 27 2008
    http://www.modbargains.com/product.a...Kit_Audi_B7_BL
    Sorry, forgot to put that in there. This was originally in the license plate bulb thread, I started a new one so it would be easier to find in a search.
    Aug 27 2008
    Quote Originally Posted by Sly Raskal View Post
    Not bad at all.
    Are the bulbs the same wattage or higher? I'm always worried about putting in bulbs that are higher than OEM wattage because it'll melt whatever housings they are put in or it'll fry the wiring.
    I actually don't know, but I'll be keeping close watch on it for the next few weeks and if I have any issues I will certainly update the post and anyone who commented in it. I would hate for anyone to follow my lead and have any issues down the road. (pun intended)
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Hey dude, I am going to order these soon. These pics look awesome. Also do all the lights pop out like the side markers or do I need a flat head screw driver?
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Aug 27 2008
    Quote Originally Posted by Turn10 View Post
    I used a small flathead for everything except the license plate bulbs. That needs a small phillips. For the dome and rear reading lights just slip it under one side and slide it over to the opposite side, it will come right out. All of the other fixtures are pretty much the same, one side can be pryed out the other cant. You'll see what I mean. There is a little mark on the side that can be pryed out.
    Am I spelling pryed correctly? I hate looking like an embusil.
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by stephengraham View Post
    gramma' ohns ju lol
    -Anil
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Nah, its pried. Its also imbusul.
    Aug 27 2008
    Yeah, I was being ironic.
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Ironical I know.
    Aug 27 2008
    Ironical I know.
    Snap. You got me on that one.
    Veteran Member Three Rings Echo3One's Avatar
    Apr 02 2007
    Phoenix
    Did the same upgrade about a year ago. Probably one my favorite mods. Since the upgrade I only had one bulb burnout and a customer service rep sent me out a replacement bulb with no questions asked.
    2021 Audi RS7 | Nardo Gray | Cognac Interior | Carbon Optic Package |
    |Eventuri Carbon Intake System |Akrapovic Evolution Titanium Exhaust | CETE Active Air Suspension Lowering Module |
    2010 Audi S5, 6-SMT | Meteor Gray | Prestige Package | Magma Red Interior |
    | APR Supercharger | STaSiS Exhaust | STaSiS Touring Suspension | STaSiS Cast Wheels 20 x 10 |
    Senior Member Two Rings Richardesty's Avatar
    Sep 07 2008
    Audi A4 Sline Quattro 2.0 Tdi
    Lincoln, United Kingdom
    Hmmmmm.......I went Blue
    I've always said - "One day I'll be able to afford a BMW, and when that day comes I'm gonna buy an Audi"
    Made in Germany - Modified in England
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Quote Originally Posted by Richardesty View Post
    wow that looks really nice!!
    TEAM|AXION
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    OP: That looks awesome!
    Did you think about putting red LEDs for the floor lights? I think the xenon/red combo would look even better!
    Btw, what are the differences between LEDs and Xenons for interior lights and which do you think is better?
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Wow! Looks great! 50 bucks is a great price
    Veteran Member Three Rings grizzles's Avatar
    OC, CA
    Quote Originally Posted by fromGMCtoAUDI View Post
    Not hating on the OP here but once I noticed this comment I had to say it....the LEDs are 10x better than the "Xenon" bulb kits. I went this same route about a year and a half ago and it looked cool for a while but the bulbs started burning out one by one. Of course the problem here is that if it burns out you have to order new ones that match and by that time you might as well buy another set due to shipping, etc. My suggestion would be to go ahead and replace the overhead lights with hyper white LEDs, those will be the first bulbs to go. It will be expensive to do the rest but I keep buying a couple here and there for when the "Xenon" bulbs burn out. My $.02....
    Aug 27 2008
    Quote Originally Posted by grizzles View Post
    Thanks Grizzles, that's good info. It's great to get experienced based feedback that actually helps refine a mod.
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    I just ordered the bulbs. They may not be as reliable as LED lights but I'm too lazy pick out all the bulbs singlely.
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    I replaced some of the bulbs on my B5 with LED festoon bulbs from this place...and they worked well.
    http://www.superbrightleds.com/festoon.html
    Maybe someone could post up a list of the sizes for each bulb?
    Feb 03 2008
    Brooklyn, NY
    Quote Originally Posted by EuroA4 View Post
    there was actually a thread for this in the past but i dont have the link saved and im too lazy to search but if you look, you'll find it.
    Ray
    Veteran Member Three Rings greene08's Avatar
    Mar 29 2008
    2023 Audi SQ5, 2024 Tesla Model S Plaid, 2022 Kymco People S150i
    Costa Mesa, CA
    Not to be a total dick here but those bulbs are not "xenon," they are just a higher kelvin color temperature output than standard bulbs. I figure it is best for you all to use the proper terminology. Xenon gas will not ignite unless under extremely high pressure and electrically charged so there is no "xenon" about the bulb.
    The bulb manufacturers mix different gasses to produce different colors (high quality bulbs) or they paint the glass with a coating to filter certain wavelengths of light to produce the desired color (lower quality bulbs).
    Lover of all things motorsport, powersport, sport.
    Senior Member Two Rings cfujikawa's Avatar
    Feb 04 2008
    these are actually xenon colored bulbs, correct? xenon refers to the gas used in bulbs used with HID's. the gas naturally gives off the clean white/blue color that everyone loves. xenon gas needs a higher voltage "spark" to ignite (or excite) the gas... hence the need for a ballast for those xenon lighting kits.
    this "xenon" kit seem to use incandescent bulbs with the blue coloring to mimic the xenon color. i say this because i noticed the bulbs pictured on the site were colored blue, and there was no mention of any ballasts.
    these bulbs have a few advantages. first, the price (cheaper than real xenons/LEDs). and they should use the same wattage as the original bulb (since both are incandescent), so you shouldn't get any bulb out warnings. the disadvantages are that they don't last nearly as long as LEDs. they'll burn out more frequently. and because of the blue coloring, they may run hotter, so you may want to keep a close eye on them.
    oh, and make sure you don't get any fingerprints or any other oils/liquids on the bulbs. it will cause the bulb to run hotter, and burn out quicker.
    : 2017 Daytona Gray Pearl Q5 2.0T Premium Plus / Tech / Sport / 20" Rim Pkg :
    : 2007 Silver Acura TL Type-S :
    : 2013 VW Golf 4-Door TDI : *gone*
    : 2006 Quartz Gray A4 2.0T Quattro S-Line Tiptronic : *gone*
    Aug 27 2008
    Correct- they are not actually Xenon.
    The kit is called an interior xenon kit, but should more accurately be called a xenon 'look' kit. I apologize if that mislead anyone. I suspect it does run a bit hotter because of the color on the glass. The only bulbs I'm concerned about are the license plate bulbs because they are on more often. The interior lights are on for such short periods of time, for me it's not as risky as the city light melting issues.
    That said, it doesn't take long for them to get to full temperature. I won't be completely comfortable with it until I've had them in for a few months.
    If anyone does this and sees any signs of melting or discoloring on the lenses, please give us a heads up.
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    +124235235 to the person that said LED's are better
    no knock on the OP, great pictures/comparison
    i originally got one of these "xenon-look" halogen bulb kits but did not like how hot they got, the comparative brightness, and the blue tint that shows through the lens cover in the daytime.
    the LEDs i purchased and used are flawless, BRIGHT and crisp, and generate almost no heat. i've had them for over a year w/ absolutely no issues. the remaining "xenon-look" halogen bulbs i left in the rear footwells are noticeably dimmer andhotter
    in short, for the interior, LEDs > "xenon" halogen kits
    oh, and NO BULB OUT warnings with INTERIOR LED's
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Nov 15 2007
    look. modbargains has interior LEDS for sale now
    http://www.modbargains.com/product.a..._Kit_AudiB7_KM
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by supamannn99 View Post
    look. Modbargains Has Interior Leds For Sale Now
    http://www.modbargains.com/product.a..._kit_audib7_km
    Lol @ "xenon Led"
    -Anil
    Sep 07 2008
    I've now updated my 'trunk' lighting (we call it a boot over here!)
    All I've done it added a couple of spare led bulbs I had, but check out the light output on the drive......
    Next up - replacement 'white' led numberplate lamps.....
