Someone on AW did it on his silver B7 S4. He did have to roll the fenders. I'll see if I can find the link...
EDIT:
http://forums.audiworld.com/s4b7/msgs/63566.phtml
In case the link doesn't work, here is a snip-it from the post:
"1:
OEM RS4 Wheels
Specs: 19x9 et29, 27 lbs a wheels. After 20,000 miles on these wheels they are still running strong and undamaged (even after driving on these POS N.J. roads), no bends or warps on the wheels after hitting numerous potholes around here so that's a big plus. They will fit over any BBK you plan on running.
The catch: In order to run these wheels in your stock B6/B7 fenders with a lowered suspension you will need to have both the front and rear fenders rolled/stretched outwards.
The only size tire you can use is a 245/35/19 tire. 255 is nearly impossible to eliminate the rubbing no matter how much you roll out the fenders. If you plan on using 235 tires with these wheels than please save your money and dont bother, you might as well stay with your stock wheel/tires since they are already 235 (regardless, it's not wise to put a 235 tire stretched out on a 19x9 wheel, any pothole you hit will destroy the rims of the wheel due to inadequate tire protection)."
