Results 1 to 19 of 19
Thread: Direct Bolt On
    Sep 23 2007
    Direct Bolt On
    Im looking replace my turbo with a k04 but it looks like they are pretty much gone for a while so i was wondering if this would be a good second choice
    http://supremepowerparts.com/applica...r_Hardware_Kit
    Veteran Member Three Rings Brooksthepro's Avatar
    Apr 29 2005
    2001 Audi a4, loud ass gocart!
    Santa Barbara, Ca
    Re: Direct Bolt On
    DOIT
    GIAC FXK04/Gen380cc/TTMAF/FMIC/custom magnaflow/710n/Labree HFC/034 Highflow Exhaust Mani/17"Team Dynamics ProRace1/CAI/race springs/Rs4 Grille/VDO vent boost gauge/SS brake lines/x-drilled rotors/12in Infinity /600w Infinity amp
    SANTA BARBARA LOCALS!! SBEUROCLUB
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Re: Direct Bolt On
    Do it nao! Get to ze choppa!
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Sep 23 2007
    Re: Direct Bolt On
    well im at college now ill prolly do this around xmas time or so but yeah what kind of chip should i run with this turbo?
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: Direct Bolt On
    I'd get the GTRS elim over the GT2X.
    The difference being that the GT2X isn't water cooled like the K03s, K04s, and GTRS/GT28 elims are.
    But yeah an elim is always a good idea since you can get much more power than a K04 with the same supporting mods.
    {99.5 Avant}
    Sep 23 2007
    Re: Direct Bolt On
    if it isnt water cooled like the k03 then how is it cooled?
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: Direct Bolt On
    Oil
    Sep 23 2007
    Re: Direct Bolt On
    so what happens with the coolant line that is running to my turbo right now?
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Re: Direct Bolt On
    Has to be pluged
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Re: Direct Bolt On
    Being just oil cooled is not that big of a deal if you have a turbo timer. If you don't you would have to leave the car running to let the turbo cool down if you want maximum life. Not to say this is not necessary to do this with a GTRS but they just don't get as hot.
    Oct 06 2004
    Minnesota
    Re: Direct Bolt On
    PES T28
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Sep 23 2007
    Re: Direct Bolt On
    i just want to spend like 1100 or a little more on the turbo nothing more i wanna get and s4 down the road and i dont wanna throw too much money in my car considering right now i have none
    Dec 05 2007
    CA LA
    Re: Direct Bolt On
    theirs a GTRS in the clasifieds for like $1025
    Dec 05 2007
    Re: Direct Bolt On
    To the OP, for $1,100 there is not much you can do. You already have an aftermarket exhaust which is a plus towards the set up. If you really want a set up for that price, you would have to try and source out the pieces till you have a complete set up. I started on this process a couple months back, but decided to go a different route and sold the things I gathered for the same prices I bought them for (was gathering parts for a full GT2871r till I decided to go a different route). So, no loss on my behalf (I do not practice usury).
    But you could make the set up work for cheap if you pick up pieces as they come along. Eliminator will be even cheaper than the full set up (assuming we are talking about the GT28RS and the GTRS). You would need at least a stage 2 clutch, MBC, AFPR, TIP, FMIC, Turbo kit (turbo and oil&coolant lines), and tuning kit (injectors and file). You can attach your current exhaust to your set up, so don't have to worry about that. Then get things to ease the driving such as motor and tranny mounts. If you take your time and source peices, you could have a complete set for maybe ~$2,250-500. But for $1,100 it is not going to happen. Even with a k04, supporting mods will cost you. You would still need all the same components (minus TIP and clutch. but I would at least get a stage 2) for a lesser turbo in my opinion.
    Or you could do as I am doing and just save money till you have enough to get what you want. I will continue to save for maybe the next 2 1/2 to 3 years for the set up I want. Till then, my flashed k03s and exhaust keep me suffice
    Last edited by Seerlah; 09-08-2008 at 08:49 PM. Reason: edit: stage 2 in place of stage 3
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: Direct Bolt On
    I'm pretty sure you will be fine with a stock clutch and a GTRS for a while. Just don't do any hardcore launches.
    Sep 23 2007
    Re: Direct Bolt On
    well i just did the clutch at 116xxx miles (stock kicking myself in the ass for not going sb but i didnt have the money i had to borrow it from my parents) so i should be good with the clutch but i also have and apr chip would i be able to run that with this or would it be better if i just ran it on stock setting? till i get money to upgrade the chip and other stuff?
    Sep 23 2007
    Re: Direct Bolt On
    like right now my turbo is about to go and i just wanna get something in there preferably anything besides a k03
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: Direct Bolt On
    Quote Originally Posted by jturnbull View Post
    do you mean kit? with tuning and hardware?
    or just the turbo as stated above?
    Sep 23 2007
    Re: Direct Bolt On
    yeah i would just throw that kit with just the turbo and mounting hard ware for now then add everything else piece by piece
