Results 1 to 4 of 4
    Feb 12 2004
    Parker, CO
    Looking to buy used B7, HELP!
    Ok, I am looking to buy a used B7 A4 but I want to make sure I am not getting in over my head. I had a B5 A4 a few years ago and I just had to get rid of it because it was nickle and dimeing me to death with all the little stuff that was constantly going wrong. Headlight switch, wheel bearings, control arms, etc. I heard the B7s are much more reliable. I will probably be buying one with anywhere from 30-50,000 miles on it. So shoot me straight, am I getting into something I will regret?
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Re: Looking to buy used B7, HELP!
    Well i have an 05.5 and the only thing that has happened to me was the pcv valve went out and the typical TSB for the ecu and the coolant O-ring on the back of the head was replaced under a TSB but other than that its been great. oh and the pass side H-light has the dipped light issue and my car has 96,000 MILES on it.
    Hope that helps!
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Registered Member Two Rings 80020vr6's Avatar
    Dec 19 2006
    2007 A4 2.0TQM (Ibis)
    Colorado
    How much are you looking to spend?
    I've got a white one with just a hair over 5000 miles on it. Just got the first service done on it 2 months ago. Got a few mods too.
    Feb 12 2004
    Parker, CO
    Quote Originally Posted by 80020vr6 View Post
    Your car looks awesome but I dont think I could afford one with only 5000 miles on it. I am trying not to spend more than about $20,000.
