Click HERE to order or for more information.
ECS VAG Jack Pad Adapter
If you have ever tried to lift a Volkswagen / Audi car from the rockers, then you know how frustrating and potentially dangerous it can be. If your floor jack is not properly placed on the rockers, they will crush and bend under the pressure causing a dangerous situation. This ECS jack pad adapter fits right into your factory jack pads, and provides a safe lifting point for any floor jack allowing you to work on your car with peace of mind.
One jack pad is required for corner, so if you typically lift your car up one corner at a time you only need one jack pad adapter.
ECS VAG Jack Pad Adapter Kit
This is a complete solution for lifting your VW/Audi without crushing the rocker panels. DIY mechanics risk vehicle damage, and personal injury when they use the flimsy rocker panels to lift their car. Our ECS jack pad adapter kit contains everything you need to lift your car safely from the factory jack points, just like the dealer uses.
This kit includes the OEM jack pads that fit into your body, and our own designed jack pad adapter that lets you lift from the OEM spots with your floor jack. Simply place the rubber plugs into your body, install the inserts, and use our adapter to safely lift your VW / Audi into the air. This jack adapter works perfectly with our Schwaben low boy jack (ES240941) for a simple solution for lifting your car.
