Results 1 to 40 of 40
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Show me your BIG, round, pointy, sweeping................. Gauges.
    Just curius if there were any creative little gauge installs. I am about to install a Autometer oil pressure gauge and just wanted to see what my options were.
    I ordered a cheapie 52mm pod cup mount for $12.99 shipped and was thinking of mounting it on the steering column. Then I got to thinking maybe there was some better options out there.(http://cgi.ebay.com/ebaymotors/ws/eB...m=270271541012)
    Its a 2.8 DD so nothing insane, and yes I know about the AC vent mount. Its not my tastes though.
    Keep wrenching.
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Established Member Two Rings lanoueb5er's Avatar
    May 25 2008
    2000 a4 1.8t Q
    montreal (I mean, Canada)
    Re: Show me your BIG, round, pointy, sweeping................. Gauges.
    If you want to mount it on the steering column, get one of these... theyre prettier and not too expensive either`:
    http://cgi.ebay.ca/Audi-A4-B5-B6-Cha...2em118Q2el1247
    Jun 12 2008
    Allentown PA
    Is there a link for the pic? Im at work now and ebay is blocked.
    Thanks
    May 25 2008
    2000 a4 1.8t Q
    That is the link to podi site it's the same pod :
    http://www.podi.ca/Img/Products/Audi/IMG_3234.JPG
    Jun 12 2008
    Allentown PA
    Snap, how much is it on ebay? Too rich for my blood, I figure the cup mounted tight on the factory column should work and look just as good and save me $67.01 dollars :)
    May 25 2008
    2000 a4 1.8t Q
    45.00$ shipped... ok It's a little more expensive then your 12$ but I think the 30 bucks difference is worth it
    Jun 12 2008
    Allentown PA
    Damn right its worth it! Ill order it tonight. Thanks!
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Does this count? .. they don't make a double column pod yet for the B5, so I DIY'd it.
    sorry, cell phone pic.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jun 12 2008
    Allentown PA
    Quote Originally Posted by djwimbo View Post
    Thats the idea!
    Where did you get the pods? How much were they? How did you mount them firmly? What gauges are those?
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Just to let you know... the pod in the eBay link (which is a ripoff of my design) and the pods that I make are not the same thing at all.
    I make a pod that replaces your OEM steering column vs. a stick on piece that requires you to cut the OEM cover to run the lines.
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Is this good.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Jun 12 2008
    Allentown PA
    ^That settles it, while I love to own your part a poor college student like myself has to have his priorities :)
    No thanks to the knock off.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by 4A Play View Post
    Thats the idea!
    Those are the $15 black pods from Summit Racing, the gauges are Stewart Warner Maximum performance (black with "alum" trim ring).
    Cheaper than VDO's and look almost identical to stock gauges.
    I pulled off the upper column cover and measured everything out so that I could still see the ambient temp screen and most of the Tach. I did have to sacrifice 0-30mph and anything >6700rpm as far as visibility goes. I used the supplied hardware with the gauge cups and I haven't had an issue with them yet. Word to the wise, if you have any of the corrugated plastic tube stuff (I forget the name) that comes with amp install kits, use that to route your boost line and wires through. It looks better than a couple wires wrapped in electrical tape.
    Eventually I will move the oil pressure gauge down into a panel where the ashtray was (like the old school 90CS Quattro's and Coupe Quattro). The other gauges I will install are a wideband, fuel pressure and EGT. The EGT will replace the oil press on the column and the fuel pressure will go down in the panel in place of the ashtray. The wideband won't match any of the other gauges, so it will go in the most left vent hole.
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    Nothing new, but it is clean and out of the way.
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    May 25 2008
    2000 a4 1.8t Q
    Quote Originally Posted by [email protected] View Post
    really? good thing to know
    Jun 12 2008
    Allentown PA
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    Senior Member Two Rings Rau's Avatar
    Dec 19 2007
    2001 Audi A4 1.8T Quattro
    San Mateo CA
    Quote Originally Posted by fred2ka4 View Post
    sick ass CF trim. where did you find that?
    Nov 26 2005
    NM
    Quote Originally Posted by Rau View Post
    I had it made but at this point I would not recommend the person as he is not reliable at this time.
    Jun 12 2008
    Allentown PA
    Theres a vendor that does it for something like $800. Insanity.
    Nov 26 2005
    NM
    Who is the vendor that you are speaking of because we might be talking about the same person. And thanks for the comments.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    When did seeing the boost or oil pressure become more important then seeing rpms above 5k? Doesn't make much sense to me.
    Jun 12 2008
    Allentown PA
    When I installed it on my 2.8 30v daily driver that doesnt get raced around the highway or shifted over 4.5k ever.
    Jul 07 2004
    socal
    Oh, would have still made more sense to mount it dead center so it just covered up only the center screen.
    Jun 12 2008
    Allentown PA
    lol but I like the trip computer. It was my first one and the pixels all still work.
    Veteran Member Three Rings chimchongdlight's Avatar
    Jan 02 2007
    Bay Area to Sacramento Ca
    freshly install last night, autometer boost gauge
    sorry for quality of pics, it was a camera fone, and it was night time, what do u expect
    Jun 12 2008
    Allentown PA
    ^What pod setup is that?
    Jan 02 2007
    just a center steering column set up, let me take some pics right now and and come right back to show u what it looks like during the day..lol brb
    Jan 02 2007
    here u go, i bought it off a member on here long time ago for a good price and just had it sitting
    Nov 02 2007
    2008 S-Line A4
    Denver
    I remember back when I had that pod setup. I ran it for about a week and got tired of not being able to see the center display.
    Jan 02 2007
    yea i think im already starting to feel that, but at least i dont have the center lcd display, so im not missing out on too much, just the outside temp.lol
    Veteran Member Three Rings ChescoS6's Avatar
    Jan 13 2007
    2012 Golf TDI 2003 Ducati ST4s ABS 2007 Ducati Monster S2R
    PA
    Jul 07 2004
    socal
    Here is pics of my gauges.
    Jun 12 2008
    Allentown PA
    ^Thats over board, mod please delete his post :)
    Nov 02 2007
    2008 S-Line A4
    Denver
    Fine Mike, you win!
    Senior Member Three Rings b5a4gt28's Avatar
    Oct 15 2007
    97 B5 BAT A4 2.0 HTA30R, 01 STG 3 S4, 04 B6 A4
    Telford Pa
    Keep wrenching.
    Sorry for the thread jack but where do you hook the oil sending unit up to? I want to get the same gauge but i have no clue where the sending unit goes...
    A4-Full-race mani, HTA 30R, Built 2.0L, AEB head, 034 IIc, 3658's, ID1000's, JM fabrications, etc...
    S4-034 tuned, 034x intake, BW K04's, OEM RS4 Goodies, EV14's, APR bi-pipe, Apikol mounts, AWE everything else.
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Here's mine... Crammed in the vent... :D
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Jul 07 2004
    socal
    Quote Originally Posted by b5a4gt28 View Post
    Buy a relocation kit from 42 draft designs
    Senior Member Three Rings TheWrightAudi.'s Avatar
    Aug 07 2008
    White Rock
    i was seriously thinking of drilling a hole in the face of the ash tray since i dont use it anyways and put a boost gauge in there. it would be easy to wire. out of the way, and hella creative...
    1999.5,1.8T,5speed,quattro.
    Understeer -is when you go off the road and see the tree that kills you
    Oversteer-is when you go off the road backwards and dont see the tree that kills you
