Results 1 to 12 of 12
    Veteran Member Four Rings AsianA408's Avatar
    '10 A5 S-line, 07 Sline A4, 99 A4q, 2002 S4,2000 S4, 2008 335i
    San jose, CA AXION BETA
    rpm needle bouncing below 10 when coming to a stop
    or slowing down? i can feel the car semi shake or sputter but it bounces right back at 10. anyone know whats going on?
    1999 audi a4q(Sold)
    2007 B7 S-line A4(current)
    2002 B5 S4 Santorin / 06 Ninja ZX-10R
    _________________________
    |.....Overnight.......................|.|\
    |........PARTS FROM........-....|.|||";,__,
    |_...__...JAPAN_______=====|.|_|..|...|
    "'(@)'(@)""'''''''"'''''''l''/(@)(@)*****(@)"
    TEAM|AXION
    "Are you a good sticker putter?" - Dino/S-POWER
    Apr 05 2007
    Re: rpm needle bouncing below 10 when coming to a stop
    Ten?
    Registered Member Two Rings lostinnd's Avatar
    May 14 2008
    Grand Forks, ND
    Ya 10 rpms
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    1,000 rpm.. Sounds like misfires.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    spark plugs or coils? which is usually the case?
    1999 audi a4q(Sold)
    TEAM|AXION
    Sep 23 2007
    did you disconnect your battery by anychance?
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    could be either spark plugs or coilpacks. pull out coil packs one by one and see if the engine noise changes. if you pull one out and the engine noise doesn't get any worse, that one is bad
    Veteran Member Four Rings Videlov's Avatar
    Jul 01 2008
    Chicago, IL, Bulgaria
    btw aren't you in the wrong forums... Unless your signature isn't updated... And it's still 1,000 rpms not 10
    "Some Redbull, some water, some nice fresh house music!"
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Active Member Two Rings ARS267's Avatar
    Dec 10 2007
    Chattanooga, Tennessee
    Mine did the same thing when coming to a stop the rpms would bounce around below 1k and sometimes it would even die. I unplugged my MAF and it went away.
    id imagine it wouldnt even start if the maf wasnt plugged in
    1999 audi a4q(Sold)
    TEAM|AXION
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I'm guessing you dont have ability to check for codes with vag-com, but that is what I would check.
    Rough idle can also be caused by vacuum leak.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    10 is 1,000 RPM's and i assume this car is an automatic. Wrong forum btw pal.
