Results 1 to 12 of 12
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    NOW AVAILABLE! JHM DIY Timing Belt DVD and T-belt kits for 2.7T
    After the success of our 01E trans rebuild DVD and Rebuild Kit we thought we would continue that success with a 2.7t and 2.8L V6 Timing Belt Kit DVD.
    Here is a link to the feeler thread that started it all -> http://www.audizine.com/forum/showthread.php?t=214697
    The DVD is free with one of our Timing Belt Kits, but can also be purchased separately if you just want the knowledge or to see if you think you can tackle the job.
    VIEW THE VIDEO TRAILER OF THE DVD HERE http://jhmotorsports.com/videos/JHM_...VD_Trailer.wmv
    ALTERNATE VIDEO LINK IN CASE DOWNLOAD IS SLOW http://jhmtuning.com/videos/JHM_2.7t...VD_Trailer.wmv
    DVD is 51 minutes in length and that whole 51 minutes is spent just doing the timing belt, water pump and thermostat. With lots of tips and tricks along the way and showing you how to do it without the expensive alignment bar or crank lock tool.
    Check both the DVD and the Timing Belt Kit with the DVD out here in our new store --> http://www.jhmotorsports.com/shop/ca..._56_60_100_131
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Established Member Two Rings Diavan's Avatar
    Sep 16 2005
    Bartlett, IL
    Re: NOW AVAILABLE! JHM DIY Timing Belt DVD and T-belt kits for 2.7T
    Awesome work Jay.
    Conway's Law:
    In any organization there will always be one person who knows what is going on. This person must be fired.
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    Can we start a blown motor thread now or should we wait for the first couple.
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    up next we should have a k04 video... maybe even a ko6 video since now you are selling RS6 turbos..... monopolize that shit! lol
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by Diavan View Post
    Awesome work Jay.
    Thanks
    Quote Originally Posted by JMTx86 View Post
    In time that could be a possibility. Maybe at least a rod swap how to. If I get a rod swap to do over the winter and have the time I can look into it.
    Quote Originally Posted by Unispeed View Post
    If it works out and I have one in this winter and I am not buried like I am now. Who know. Monopolys are where it is at SON!
    And
    Aug 24 2005
    Lathrop, CA
    Here is a Question I was asked via email. So I thought I would share.
    Jason,
    I was wondering if you use OEM parts in your timing belt kit? Also,
    does your video show anything as far as replacement of the cam and crank
    seals? Lastly, i know it says the video shows you how to replace it
    without the camlock bar, but does it give any info on how to do it with
    the bar?
    Answer I responded with:
    They are all high quality after market German made replacements. Been running them on my car for 30k plus miles with tons of 7300 rpm abuse. My car is the test mule for my shop and most its miles are at the track or for R&D and around town.
    VAST Performance has been using the same brands for a long time as well. The belts are both made by Continental. Same as the tires company that makes tires that are OE on Mercedes. Big brand overseas.
    I do show how you would change the cam and cranks seals. I don't do the seal replacement but I show you how the tools connect and how you would get it apart with much detail. Basically a steering wheel and 2-jaw puller are all that are needed. I spend several minutes just showing this.
    I also point out where the cam lock bar goes and make it clear on how it is used.
    I have done hundreds of timing belts in my life on at least 50 different motors across many brands. So the info I give comes from that experience.
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    I covet timing belt video.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Aug 24 2005
    Lathrop, CA
    (NOTE: correction in the DVD, it is a 24mm 12 point socket for the crank bolt NOT a 25mm 12 point, we will update DVD soon)
    Other than that the feedback is awesome.
    Thanks to all who have purchased thus far.
    Aug 24 2005
    Lathrop, CA
    Thanks for all the purchasers thus far. I appreciate the positive feedback. This encourages me to make more videos like this.
    Aug 24 2005
    Lathrop, CA
    UPDATE 2-13-09. We recently added extra footage to our DVD for use of the cam lock bar and crank lock pin, we also now offer a $40 rental cam lock bar and crank lock pin as well.
    Thanks to all of the purchasers thus far.
    Senior Member Three Rings jblinga's Avatar
    Jul 24 2008
    '01.5 S4, '96 Maxima
    Mor_onville U.S.A.
    This vid definately helped out! I did mine 2 weeks ago and it was easy.
    +1000 for JHM
    '01.5 S4 6MT 2+
    '96 Maxima (DD)
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by jblinga View Post
    +1000 for JHM
    Glad to hear, thanks for the feedback.
