Results 1 to 2 of 2
Thread: CEL code 16815
    Veteran Member Four Rings 10MPG's Avatar
    Oct 25 2006
    Current:
    Bay Area CA
    CEL code 16815
    To set the stage - I have a FI fullback exhaust and it's been running perfectly for about 2 yrs now. Last month while I was at a stop light, the engine starts sputtering during and my CEL came right up.
    The fault codes I pulled are:
    16684 - random/multiple misfire
    16815 - warmup catalyst below threshold
    16691 - cylinder 7 misfire
    Since then I have cleared the code and luckily, the only one that came back is the 16815 code.
    I spoke to Audi technicians about this and they said the misfire can happen because lack of back pressure from the fullback exhaust unless I have a bad coil which I don't think it's the case here.
    Hopefully you guys can help me out with the last CEL code....I've seen similar code in B5s but nothing yet in the B6/B7 section.
    So far, I've tried repositioning and even switching O2 sensors but nothing works yet so I thought I toss is out here and see if there are any other tricks other than getting a new cat. Help an Audi brother out!
    Here's the log for your ref:
    16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
    P0431 - 001 - Upper Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 68916 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1472 /min
    Load: 45.1 %
    Speed: 53.0 km/h
    Temperature: 98.0°C
    Temperature: 50.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.843 V
    Dec 05 2006
    So. Cal.
    Re: CEL code 16815
    Sounds like a coil pack to me.
