alright, need help. i pull into my parking spot after a 40 mile drive and my hood starts smoking once i am about to turn off the car. I look at my drving path and there is a leak of fluid that just decided to start as i entered my garage. i look under the car and it is dripping a lot. I check my dipstick and it is at it's minimum level. I look under the car and see that the oil has be running down other parts and is leaking from the center of the car. I try to trace the source but can't find it. drain plug is fine, no cracks in the pan. I jack it up and look up and see a bunch of hoses wet. NOt sure if that is from the oil running down these parts or what. the head and black seemed dry as well. where else does the oil go that i shoulud look at. is there a hose i don't know of?
