Results 1 to 9 of 9
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Arrow Experiencing a myriad of problems -many pics
    Hey guys,
    Lately i've been experiencing a few problems with my car ever since i got my coilovers 3-4 months ago. While on the freeway, the rear of the car starts vibrating subtly and it only happens on the freeway at 75+ mph.
    Then on Friday, Sept 5th, I took my car in to Penske Audi for a check engine light, got it back the same day, and ever since then, i've been hearing abnormal clunks and stuff from the right side of the car when i go over bumps and dips. I dont EVER speed over dips and bumps because i'm pretty low all around. tonight when i went under to check up on my car, i saw that the RS4 swaybar endlinks were rubbing against the right axle and leaving a groove in it.
    (this is on the passenger side.)
    Then when i took off the front wheel, i also saw something i THOUGHT was abnormal but didn't think it was that big of a problem. Apparently, the helper springs on my bilstein shocks were completely compressed and i didnt realize it was that big of a deal until i saw a picture i took of it a week ago.
    Heres the front driver's side shock with the wheel off and on jack stands (A WEEK AGO):
    The shock now. It's the same WITH and WITHOUT weight on it so something's definitely different. (sorry for the bad picture. didn't want to take wheel off):
    My initial assumption is that the mechanics at the dealer lifted the car up and somehow dropped it on the ground blowing my front shocks... but the funny thing is that my rear shocks are fine..
    Oh and one more thing: they fucked up my jack points on 3 corners of the car. As a result, the area below the side skirts is a little bent. Heres a pic of the passenger side rear jack point:
    Anyone know what the fuck is going on with my car?
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Re: Experiencing a myriad of problems -many pics
    If you're hearing abnormal 'clunking' sounds and so forth post service visit, you should definitely take your car right back to Penske first thing on Monday or Tuesday morning and address the issue(s) them asap - along with the pics!
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Mar 02 2007
    Brisbane, Australia
    Those jack points are messed up !! I'd be unhappy with that
    Regarding the front coilovers - sounds like you're getting some bad stiction on the shocks. (the inner & outer shafts are binding up rather than sliding in and out...). Not good - I can only recommend getting back to the installer for a closer inspection.... Good luck...
    I've never heard of the RS4 rear bar touching the drive shaft like that - might need to trim the ends of the bar...
    Has the car ever been in an accident ? Wheels alignment/geometry in order ??
    Nov 16 2007
    Westerly//Providence
    Quote Originally Posted by DownUnderSLine View Post
    x2 that's what came to mind first for me.
    Nov 15 2007
    Nope. No major accidents where there was body damage. the only accident was a minor bump to the rear end:
    http://www.audizine.com/forum/showthread.php?t=202355
    My alignment should be fine.. i got an alignment a few weeks after i got my coilovers. I always drive cautiously and avoid potholes and stuff..
    is there any way to fix the jackpoints?
    DUH! an Audi
    los angeles, CA
    to fix that you need something new kev, take it to penske they will take care of it..else call me..daddy will help you lol
    -randy
    Nov 15 2007
    haha thanks randy.
    so noone knows or has an idea wtf is wrong with my shocks? :(
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    did you try contacting Bilstein for advice? As for the jackpoints, they just suck. One of mine is messed up but I don't know who did it (me, buddy, or dealer).
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by supamannn99 View Post
    Hey guys,
    You better make them pay to fix those jack points. They maycause you some futureproblems along with a lower resale.
